Poser/DS compatible product?
http://www.daz3d.com/shop/warraok-kitt/
Just curious if this is compatible with Poser/DS, almost went to purchase it and it only says Bryce, however http://www.daz3d.com/shop/licorne/ is the complete opposite, but the style/render of the promo images look nearly identical, was just wondering before I commit to something that I shouldn't.
  • SlimerJSpudSlimerJSpud Posts: 1,453
    The Warraok Kitt is clearly Bryce only. The Licorne says Daz Studio, Poser under Compatible 3D software. You can do a lot in either program with a sky dome and a water plane.
  • edited December 1969
    I know it says Bryce only, but between the two products, they look like they were rendered in the same program, which sucks 'cause I really wanted the Warraok
  • JaderailJaderail Posts: 0
    edited July 2012
    Both are by the same PA. They do very good work, I also wish BOTH were for DS.
    Edit to add they might have been Rendered in Bryce by use of the Daz to Bryce bridge.
    Post edited by Jaderail on
    perhaps we should make a request of the artist to make them compatible? :D
  • ReDaveReDave Posts: 815
    That's probably an error, I've never heard of Faveral doing Bryce items. The readme on this product clearly shows pp2 (Poser) files, so it can be loaded very well into DS, you just need to adjust surfaces.
    I do belive that is the DS conversion of the Bryce item. But Daz has a thirty day money back guarantee so if you wish you could try the item. If it is only for Bryce just ask for a refund.
