Josie has lines on her legs
areg5areg5 Posts: 617
I haven't been able to correct this. I have tried UV sets for basic female, girl6 and victoria 6, as well as leaving it blank. Any ideas?
  • Dream CutterDream Cutter Posts: 1,224
    What level of density are you using? I get that effect when I use the original UV on lower res. decimation of Girl 6. Do you see this in the base level of detail renders? Assuming render is "Best" setting?
  • areg5areg5 Posts: 617
    Yes, it is set at best using Delight engine.
  • SloshSlosh Posts: 2,391
    edited October 2013
    Extremely easy to fix. Go to your advanced render settings and change the Shading Rate to .2 (in case it's hard to read, like on my screen, that is "point 2", as in 0.2)
    This will fix it, at least at render time.
    Post edited by Slosh on
    That almost worked. I turned it down to .1, and it worked fine. Thanks!
