Josie has lines on her legs
areg5
I haven't been able to correct this. I have tried UV sets for basic female, girl6 and victoria 6, as well as leaving it blank. Any ideas?
816 x 614 - 282K
What level of density are you using? I get that effect when I use the original UV on lower res. decimation of Girl 6. Do you see this in the base level of detail renders? Assuming render is "Best" setting?
Yes, it is set at best using Delight engine.
Extremely easy to fix. Go to your advanced render settings and change the Shading Rate to .2 (in case it's hard to read, like on my screen, that is "point 2", as in 0.2)
This will fix it, at least at render time.
That almost worked. I turned it down to .1, and it worked fine. Thanks!
