Copying every character map and save it to a target directory
Hi,
Sometimes I use LIE stuff or change certain images of a character (irises or selfmade ps modifications e.g.).
Is there a way to copy ALL character maps and save them to a chosen directory, ideally also with a material preset for it ?
Something like https://www.daz3d.com/lie-baker would be perfect, but it saves the temp LIE maps only.
Thank you
P.S. I know how to archieve this manually :)
Post edited by Mazh on
Skin Builder 3 & 8 can do that via its saving option. It will bake LIE and all maps on figure and save them as a loadable preset with it's own resaved maps.
Thank you very much Zev0, own just SB G2F atm, but SB 3 is on my wishlist :), is it possible to use SB 8 with G3F UVs, read somewhere (one of your posts?), that the eye UVs are slightly different ?
"is it possible to use SB 8 with G3F UVs, read somewhere (one of your posts?), that the eye UVs are slightly different ?"
Yes you can, and yes the eye UV maps are slightly different. You can easy just load eye preset from another G3F skinset afterwards if the G8 eye maps causes any visual issues. Also eyelash maps will have to be applied manually.
Great, thank you again, Zev0
NP.
