Adding to Cart…
There's no way to know that since we can't convert existing hair for now apparently....
No. There are no changes in this build that should have caused any new issues with the database (or its constituent parts). If there were any changes in this build that even had the potential to negatively impact the database, they would have been mentioned in the first post of this thread (as has been the case many times in the past).
More often than not these types of issues boil down to misconfiguration, misunderstanding, or miscommunication. Often times you will see Richard (or one of the other moderators, or Customer Support personnel) ask you to provide various screenshots so that they can verify paths and settings. You may have already experienced this yourself.
As we are not across the finish line with development yet, I'll leave this particular issue to the support staff to step in and assist you.
-Rob
Have you used them in the beta before? Are they still available in teh release build? How did you install them - DIM or Connect?
I thought I used them in the beta, but not sure anymore. Just remembered I did not use Smart Content to use George 8 but I used the shaping pane to use George 8.
Should loading the G8M Strand Based Hair sample load another instance of G8M? Because on my computer, it is. When I load the hair, it loads another G8M, even tho I have one selected in the scene already.
Laurie
I know this is a really stupid question, but how does one erase? I've never used Garibaldi.
Laurie
If you are talking about the paintbrush then take the slider down from 100% to 0% or whatever it is at the other end, then paint back over where you've been.
Edited to add that it's not a really stupid question :)
This looks like an awesome feature and I'm very excited to play with it!
Is anyone else having trouble getting it to show up even when rendering a full image (not the Iray viewport preview but the actual render)? I can use the tool to style it just fine, but the first render I tried finished totally blank within about thirty seconds, and subsequent attempts have successfully rendered G8 but not the hair itself.
Also when I turn on "Preview PR Hairs" the hair vanishes, even if I'm not previewing in Iray.
Edit: After some experimenting, it works just fine on torso, arms, and head. The issue is only happening when I try to add hair to the legs.
THANK YOU! I was going nuts. LOL
Laurie
Practical suggestion: Reset to default option on each page of the editor, for those times you totally screw something up and there aren't enough "undos"
How can we save the strand hairdos we create?
Gee, it sure would be a good thing to have that product documentation when DAZ roills out a major new feature, wouldn't it? Only DAZ...
Maybe you can save it as a scene or subset?
OK Daz Beta is not showing up in DIM but all the other Beta stuff is. Is there a way to get it without depending on DIM
Getting this in the DIM logs Product 12000-4:DAZ Studio 4.11 (Mac 64-bit) Public Build +BETA+ has no tags
Product 12000-3:DAZ Studio 4.11 (Mac 32-bit) Public Build +BETA+ has no tags
Product 12000-2:DAZ Studio 4.11 (Win 64-bit) Public Build +BETA+ has no tags
Product 12000-1:DAZ Studio 4.11 (Win 32-bit) Public Build +BETA+ has no tags
Product 12000-43:Scene Builder for DAZ Studio Public Build +Beta+ has no tags
This looks like an error: When I load "G8F Strand-Based Hair Mohawk.duf", the hair is listed as "dForce Mohawk Female" in the Scene pane.
It does. It loads the gray dev character from both the dForce & strand based samples.
You are probably rendering in 3DL mode but by default the hair you create is iRay. Make sure you use the 3DL sample and create hair in 3DL mode.
Hey, thx again for this Update und Information about "strand based hairs"!
Great :-)
Two observations for DAZ about curve selection sets, one of which is a 'needs fixing sooner rather than later' thing, and the other being a 'more than useful if we could have it' thing.
First, if you look at the attached image you will see that I have created a bunch of curve selection sets and have selected the right hand side. Look at the list of sets now available to use and you can just about see it - others beneath it can't be selected using the mouse as there is no scrollbar. This needs fixing.
Secondly, it would be nice if sets could be selected and made invisible so that you can go on to create others knowing that you won't be including hairs that you'd included in the first ones. As far as I can see, there is no other way of telling.
Thanks in advance for putting these things on the 'Let's get it done yesterday' list ;)
Thank you, @rbtwhiz. You seem to go unthanked a lot. Maybe its just my impression. I appreciate the things you do. Now... back to work! Bring us the next new and exciting thing.
I can't see the Beta in my DIM list. Also looks like other DAZ Studio's installations are missing.
I see other people already updated, I'm the only one who has this issue?
@Imago
I had the same problem with the not visible in the DIM List.
The only possible Solution was to download the zip File an transfer the File to the DIM Download Folder.
PC1 - Visible in DIM List
PC2 - Not Visible, DIM Downloadlink SKU 1200 give only a 1kb File Beta Content but not the Pro Beta Installer
Check your DIM Download filters, the Public Build should be checked.
What DS installations are missing?
Is it SUPPOSED to be incompatible with DS3 content? As it stands, I've got an entire content folder that I might as well right off entirely as far as mesh assets (scenes/props/characters) are concerned, and the same is true of the Optitex free dynamic outfits. Scripts and lights still generally work, and 3DL shaders (more or less), but anything with geometry seems to be stuck behind an upgrade-wall.
Yes, checked, all is set the right way.
I installed one of the old Betas a couple of days ago, then I uninstalled it due to the Custom UVs bug.
It seems the other DAZ Installations (Non-Beta ones) are in the list normally, only Betas are missing.
I hope a stable version that is not in beta can come out now.
I'm forced to use the beta because of a 2080ti, but it always crashes when I have a lot of things in the scene and I'm trying to pose chains or ropes from Sickleyield with the active pose tool.
This dosen't happen in the current stable version. So I'm forced to use both versions, the beta for rendering and the stable one for posing chains.
This update did also not fix this, if anything its worse than before.
I have never rendered in 3DL, so I'm not sure how this works. Do you mean I need to create it in 3DL mode and then render in Iray?
To clarify, the hair is rendering in Iray just fine as long as I keep it to the head, torso, and arms. If I painted on just the torso and legs, though, it didn't work.
Older .daz scenes have been getting sort of "phased out" for years already (remember there was first a problem loading DS1 .daz scenes in as early as DS3, and so on). Optitex dynamic freebies have been giving errors since a couple beta versions back at least.
If you have an older DS installer handy, such as 4.6, it should be able to load the Optitex files, and then you could save them out as .duf dynamic assets. It's what I have been doing. But of course it implies you either have a spare computer to run the 4.6 on, or use the beta as your "production build" (or are willing to downgrade for an evening or two dedicated solely to updating all those files).
The current General Release can handle .daz format files, and one can install both the Beta and Current Release on the same machine.
I don't see it in DIM and I have "Public Build" checked in "Download Filter" and "Display Hidden" checked. Any suggestions on how to get it to show up?
Beta software gets beta documentation. Doing anything more than that before an official non-beta release makes no sense since things will just change. And that's a universal truth across all software development.
