Gaps in the skin
reserv888reserv888 Posts: 1,164
edited October 2013 in New Users
Why do I get these gaps in the skin (on the thighs)? More importantly; how do I solve it?
(The gaps only show up in the render).
Post edited by reserv888 on
  • SimonJMSimonJM Posts: 6,084
    That looks like it would be a UV map/seam issue - check that the UV map set for hips and legs are set to the same, correct, setting for the skin texture in use.
  • Richard HaseltineRichard Haseltine Posts: 109,590
    What is your Shading Rate, in the Advanced tab of Render Settings? If you select the legs or hip with the Surface Selection Tool, what shader is listed at the very top of the Surfaces pane, above the list of surfaces?
  • reserv888reserv888 Posts: 1,164
    edited October 2013
    @Richard
    My shading rate is 2.00
    Shader is "default"
    @Simon
    I an still a newbie. Where/How do I find the UV maps and the setting for the skin texture?
    (I do believe I have used GabiV5, if that has anything to do with it.)
    The gaps only occur when I use 3Delight software render. Not in OpenGL (with or without shadows)
    (I can't use OpenGL SL at all. Makes Daz Studio crash, but that is another issue).
    Try dropping Shading Rate - to 1, then to .5, then to .2 - until the seams (hopefully) go away.
    @Richard
    Thx, that did it.
    What does the Shading Rate actually do? Noticed that is distance dependant. The further away the lower I have to set Shading Rate.
    If I am close to the figure I can use a significantly higher setting.
    Shading Rate is explained at the top of this page http://www.k-3d.org/wiki/RenderMan_Controls
    @Richard
    Great link. Thx alot! Answers to a lot of questions I had.
