Any Bikini Morphs Out There?
WSC
Swimsuits create tension around where the edge of the garment pulls on the body. Any morphs that create this? I can see where this would be challenging as not garments are the same....
Post edited by WSC on
the3dwizard has some. Search for Realfit. Outoftouch has some. Search for micropressure.
You could try this freebie script before spending any money.
https://www.daz3d.com/forums/discussion/325096/mcjsqueeze-script-to-create-constricting-morphs-ex-tight-stockings
Some of OutOfTouch's lovely underwear has shaping morphs. I have Lainey Lingerie and the morphs really do look rather good close up, though I don't know how they would look with other undies/swimwear.
Free is definatley good. I'll check this out....
Thanks. Outof Touch generally has really good stuff!
Its a tough one as the clothing item needs an actual morph itself to cut that close in to the body, Somtimes negative values of the generic 'expand' morph will do it, but not always.
As a rule of thumb clothing items are not permitted to touch or intersect any geometry of the figure (out of the box,) Daz sends them back for fixes if they do, as its basically considered as poke through :)
So its really at the discression of the clothing vendor to provide such morphs for their tight fitting items
