mcjSqueeze - Script to create constricting morphs ( ex: tight stockings )
mCasualmCasual Posts: 4,607
edited May 2019 in Freebies
mcjSqueeze is ready !!!
( figure must be zero-posed for the morph creation but hey better that a kick in the, i mean better than nothin )
https://sites.google.com/site/mcasualsdazscripts9/mcjsqueeze
Post edited by mCasual on
  • Silver DolphinSilver Dolphin Posts: 1,638
    Once again, really useful script!!! Thank you very much.
  • This is excellent! Thanks!
  • N-RArtsN-RArts Posts: 1,606
    I'm in love with this script. I gave it a try earlier, and I was really happy with the result.
    Thank you for creating and sharing.
  • SixDsSixDs Posts: 2,384
    Thank you, Maestro!
    thank you.  this looks handy.
  • KitsumoKitsumo Posts: 1,221
    Awesome. Thanks!
  • What does this mean and how do I fix this
    478 x 159 - 17K
  • Rod Wise DriggoRod Wise Driggo Posts: 2,321
    Just found this. Looks interesting. Any chance to modify this a bit so it may cover as well pressure from i.e. panties?
  • mCasualmCasual Posts: 4,607
    edited July 2022
    it squeezes the tube-shaped body parts like the thighs for example, like a rubber band , or it unsqueezes them (bulges)
    making the cloth part of panties squeeze the buttocks would be complicated or impossible
    but
    i have a script named mcjElevate that's very simple to use, coupled with mcjTemplate
    and bump/displacement maps you may be able to sculpt that area into something that looks like the desired result.
    mcjElevate converts bump maps into morphs, you can use it to turn a 100x100 primitive-plane into a terrain with mountains and roads etc
    and when applied to a thigh or buttock you can reshape them
  • It works fine! - Awesome - Thank you!
  • atoxicatoxic Posts: 155
    Thanks.
    Your scripts are very helpful, I appeciate that you share them with us.
    Nice Days and Nice Renders
    atoxic
  • bngcombngcom Posts: 1
    It seems to be a great tool, but I can't get it working. I tried every trick I could think of. Is it just not compatable with Daz STudio 4.21 ? It tells me it is processing vertices, but at the end I see no change to the figure. I selected the whole figure, just the upper arm, I tried it on Mac, on Windows, with genesis 3, 8.0 and 8.1 but I do not see one single change to the shape of the figure. I tried 10 different splines, nothing ... Or am I missing something, just an other action ? I keep the human figure on its place (only raise an arm to get it horizontal for genesis 8 & 8.1), create a cylinder that I rotate 90 degrees to get it as shown on the example pictures. But nothing. Any suggustion ?
    Found it out at last. It works well, the result will be a morph visible in the Parameters tab of your figure (f.i. Genesis 8 Female) under Morphs. What I did not realise is that the morph is NOT applied so you will not see the result; you have to browse to the morph and use the slider to see the effect. I also found out that using a cylinder with smaller length (y) may give nasty results; give it a length as shown in the example. You can find an explanation of how to save the morph with your figure in the manual of Meshgrabber. Succes !
