[Released] RSSY Hair Converter from Genesis to Genesis 8 Female [Commercial]
2
  • carrie58carrie58 Posts: 4,098
    edited May 2019
    @RiverSoftArt You are welcome ...... didn't look like a bug to me ......not enough legs ....
    Post edited by carrie58 on
  • ArtiniArtini Posts: 10,347
    carrie58 said:
    Artini said:
    How to deal with Genesis hair in .dsf format?
    The script do not open them at all.
    Load them on Genesis and then resave as a figure/prop asset /follower/ hair ,and then convert to G8
    Thanks @carrie58smiley
    BTW, this is a bug. I will modify the script to accept dsf files.
    Thanks a lot - it will save me even more time on the conversion. I have started with .duf files first.
  • RiverSoft ArtRiverSoft Art Posts: 6,800
    You're welcome!
  • DripDrip Posts: 1,238
    Soooo hoping for the converter from V4! I have dozens of great V4 hairs in my library already, and there are even more I have wishlisted because it's generally a pain to properly fit them on G3/G8 and didn't purchase yet because I practically never use V4.
    We are getting there.  smiley  If sales keep doing well enough, we will go back to v4/m4.
  • CybersoxCybersox Posts: 9,296
    Ditto.  The switch from dsf to duf was one of the most poorly thought out
    Between all the DAZ clearance sales and items picked on the cheap during Rendo's big sales, I have literally HUNDREDs of V4 hairs.  I would gladly pay for a V3/A3 hair converter as well. :)
    The fix for adding dsf files is in the Daz testing pipeline.
    That would be up to Sickleyield.  I definitely don't have ANY V3/A3 stuff!
    Thanks for the update, RiverSoftArt.
    I have already converted some of the hair in .dsf format.
    edited May 2019
    Converted Despoina Hair - https://www.daz3d.com/despoina-hair
    Hair materials converted with: https://www.daz3d.com/rssy-3delight-to-iray-converter
    800 x 1080 - 185K
    Post edited by Artini on
    edited May 2019
    Converted Aspasia Hair - https://www.daz3d.com/aspasia-hair
    800 x 1080 - 218K
    edited May 2019
    Converted Marja Hair - https://www.daz3d.com/marja-hair
    800 x 1080 - 186K
    You're welcome!  And thanks for posting pics!
    edited May 2019
    Thanks. As usual this converter saves a lot of items from being forgotten and not being used so often.
    I like to hear that! smiley
    edited May 2019
    800 x 1080 - 247K
    Artini said:
    Nice!  That is a good image.
    Thanks a lot.
  • missuskissesmissuskisses Posts: 918
    edited May 2019
    So, some hairs are not being recognized as hairs at all, for example, Georgina Hair for Genesis, or any of the Pure Hairs. They are in *.duf format. Anyone else having these problems?
    Edited to add: OK, I went to the Options tab and unchecked "Check Content Type When Adding Files" and that seems to work.
    Post edited by missuskisses on
    edited May 2019
    What does the log say?
    You can turn off the content check and Add Files to the list.
    Post edited by RiverSoft Art on
  • 3Ddreamer3Ddreamer Posts: 1,347
    I found that on those hairs when I ran the Genesis to G8M version yesterday, they still weren't recognised after unchecking Check Content Type, and added them with the Add Files. I am not on that computer at the moment, but I have a list of some of the ones it didn't recognise and can get the logs when I am later. There were duf files, dsf files (which is known about), and hr2 files (though I wasn't really expecting them - I forgot some Gen hair were hr2 files - Historical Curls for one)
    And did you try and force convert?
    The missed duf files wont even load in the list, says there was no Hair found when you try to add the file.
    If you turned off Check Content File, the "Add Files" button will load *any* file.  I think you must have tried Add Directory.
    Thanks - I'll try again when I go onto that laptop, I was pretty sure I'd tried all combinations, but...
    Yeah, it is easy to miss a combination smiley  Please let me know.
    Okay just checked again - from the logs it looks like the hair giving problems are saved as scene-subset, which is annoying :-(
    I've attached a list of the Genesis hair that I've spotted that are not being detected automatically (hr2 and dsf understandably, duf - scene-subsets disappointingly) for your info if you want to experiement. I've more from Rendo (SAVs) not playing nice either.
    1920 x 1080 - 242K
    txt
    txt
    Convert.txt
    78K
    txt
    txt
    genesis hair.txt
    393B
    Ok, the scene-subsets are definitely going to be ignored (who saves hair as a scene subset?!?).  smiley  Unfortunately, I have none of your hr2 hairs to test on.  PM me with your email address and we can try and work it out.
    Never entered my head they would be scene-subset either, until I looked in the log. I guess it was early days of DS4 and it seemed like a good idea at the time. sad I wasn't expecting a fix for hr2, I guess they are a hang-over from M4/V4 as well, but if you get to M4/V4 they may crop up again. I'll send you a PM smiley
    and I will poke my nose in here and again suggest to load the ones that won't convert onto the original figure and re-save as a "Figure/prop asset /follower/Hair  ... save into the original folder it should be a duf  then try to convert .......sure it's an extra step but totally worth it
    I will do Carrie. Found that the hr2 files all seemed to be made for M4 with a Genesis fit - I think they'll get converted with a M4-G8M converter - only need one copy for G8M afterall. The scene-subsets I'll have to do as you say.
