https://www.daz3d.com/20-unique-smiles-hd-for-genesis-8-males-
I have a problem with https://www.daz3d.com/20-unique-smiles-hd-for-genesis-8-males-.
I have downloaded this product via DIM but when I call it up in Smart Content, all I get is the "Unique Smile HD Reset".
When I manually downloading the zip file and I go to the data, runtime & people files under Content, the individual files are all there already!
Have I missed something?
When I use DIM, normally the product works perfectly but for some reason this one doesn't!
Any suggestions?
  • LeanaLeana Posts: 13,536
    Looking at the product description I’d say it’s normal you only have a preset to reset the smiles in content library.
    The smiles themselves are listed as “pose control morphs” so my guess would be that they’re just new dials you should find in the Parameters and Posing tabs and they don’t have a corresponding preset to apply them.
  • MGMOZMGMOZ Posts: 108
    Ah yes! Thank you, Leana! The difference is that you have to highlight the character itself and not just the head on the Scene Tab before highlighting the expressions on the Posing Tab.
    Again, thanks for your help!
    Cheers!
    Cheers!
    Thank you for this! It was driving me crazy not finding these! I usually select the head and look for expressions within the parameters tab. I'll have to remember to select the figure and use the posing tab instead. D:
  • vwranglervwrangler Posts: 5,049
    What I've discovered is that if you select the root level of the character, then the Pose controls for the head, all the expressions will be available. If you select the head first, then the pose controls, only some of the expressions will be available. It seems to depend in part on whether the vendor did ... something. No idea what. I don't know why that difference is there, but it is.
