Medieval Morphing Dress sleeve morph question.
Mr Gneiss Guy
It looks like there is a "Sleeve Short" morph, but I don't think any of the promos show it applied. Is it possible to shorten the sleeves to show the hands like in a bathrobe?
Post edited by Mr Gneiss Guy on
I'd like to see that too. The sleeves are what has kept me from picking this item up.
I just realized that I spelled Medieval incorrectly in the subject. I can feel you all judging me, stop it! :roll:
Corrected now.
Yes, I think it would work wonderfully as a bathrobe or dressing gown if the sleeves weren't as long. And there appears to be a morph that adjusts sleeve length, but I wonder if it does it enough.
hi
i ve got the same problem
there is a dial but not enought to see the hand
but someone succeeded
http://www.daz3d.com/forums/discussion/30182/P180/
otherwise it's a nice product
It's true to form for the period it represents. If you still want to make the sleeves shorter, you can click the gear icon beside the short sleeves morph to bring up the parameter settings dialog; remove the check mark beside "use limits"; then click accept. This will allow the slider to move beyond the creator's intended limits.
thanks pixel8ted
