Commercial: DP Teen Josie Carrara Shaders. Save 30%
ringo monfort
DP Teen Josie 6 Carrara Shaders is a set that comes with six stunning skin shaders. This product takes advantage of Carrara's most advanced shader features to create natural and photo-realistic looking skin shaders. Add a striking look to your renders with DP Teen Josie 6 Carrara Shaders.
http://www.daz3d.com/dp-teen-josie-6-carrara-shaders
30% OFF NOW.
Thanks for these Ringo.
So far, I have tried the first two shaders. Both have a visible white line between the Hip area and the leg area.
ncamp
Hi,
First time I see the Texture map Filtering of "Fast Mip Map" do this.
For both shader domains "Legs" and "Torso" do this.
In the Color channel you will see the Texture map and its Filtering is by default set to "Fast Mip Map" change it to "Sampling".
Gorgeous shaders for such a cute kid! Bravo, my friend!
Thank you my friend. :red:
I love the Carrara render engine... Look at Teen Josie.
Great work on the shaders, Ringo!
Thank you Phil.
Close up of Teen Josie 6 Skin Shaders.
