Commercial: DP Teen Josie Carrara Shaders. Save 30%
ringo monfortringo monfort Posts: 945
edited December 1969 in Daz PA Commercial Products
DP Teen Josie 6 Carrara Shaders is a set that comes with six stunning skin shaders. This product takes advantage of Carrara's most advanced shader features to create natural and photo-realistic looking skin shaders. Add a striking look to your renders with DP Teen Josie 6 Carrara Shaders.
http://www.daz3d.com/dp-teen-josie-6-carrara-shaders
30% OFF NOW.
500 x 650 - 115K
500 x 650 - 142K
500 x 650 - 103K
500 x 650 - 180K
  • ncampncamp Posts: 345
    edited October 2013
    Thanks for these Ringo.
    So far, I have tried the first two shaders. Both have a visible white line between the Hip area and the leg area.
    ncamp
    640 x 480 - 57K
    Post edited by ncamp on
  • ringo monfortringo monfort Posts: 945
    ncamp
    Hi,
    First time I see the Texture map Filtering of "Fast Mip Map" do this.
    For both shader domains "Legs" and "Torso" do this.
    In the Color channel you will see the Texture map and its Filtering is by default set to "Fast Mip Map" change it to "Sampling".
    640 x 480 - 75K
  • DartanbeckDartanbeck Posts: 22,153
    Gorgeous shaders for such a cute kid! Bravo, my friend!
    Thank you my friend. :red:
    I love the Carrara render engine... Look at Teen Josie.
    1000 x 1300 - 377K
  • PhilWPhilW Posts: 5,162
    Great work on the shaders, Ringo!
    Thank you Phil.
    Close up of Teen Josie 6 Skin Shaders.
    902 x 1188 - 497K
