Problem with LY Harleigh for Genesis - fixed by updated product
alkenalken Posts: 272
edited October 2013 in The Commons
This install screws up the base Genesis figure, I hope there will be a fix soon.
  • VisioneerVisioneer Posts: 158
    edited October 2013
    Did you apply the V4 shape for Genesis? Or is that how the Genesis 1 base loads when you load a new one into the scene?
    Post edited by Visioneer on
  • LyonessLyoness Posts: 1,641
    This is not a screw up. The Harleigh morph has been correctly applied to Genesis.
    Next you need to apply the V4 shape. I have conveniently included a link inside of the Harleigh folder.
    Just keep clicking through the links and Harleigh will appear complete.
  • alkenalken Posts: 272
    edited October 2013
    Photo is of the base Genesis without any morphs applied. If I remove Harleigh from the data folder my Genesis returns to normal.
    Post edited by alken on
  • TimbalesTimbales Posts: 2,451
    I have the same problem - load Genesis and Harleigh is already 'turned on'.
  • SpitSpit Posts: 2,342
    I''m seeing the same thing. :(
  • Johnny RicoJohnny Rico Posts: 64
    I am having the same problem. The default genesis figure starts with the Harleigh morph on. I also hope this is fixed soon.
    edited October 2013
    So, is there a way to fix this so we don't have to wait for an update? I mean besides manually zeroing the morphs.
    Daz and I are looking into this problem. I am truly sorry and seeking a quick resolution.
    ok. Especially for you forum people. You can edit the LY_Harleigh_Body.dsf located in the data folder. (daz3d:genesis:base:morphs:Lyoness:LY_Harleigh)
    Line 32 says: "value" : 1,
    change that to:
    "value" : 0,
    and everything will be fixed.
    An update is being posted to the server right now and will be available in an hour and a half.
    Thanks. Had to do the same thing to the face.
    yes. the update fixes both.
  • RiggswolfeRiggswolfe Posts: 916
    That was a very fast reaction Lyoness. Quite impressive!
  • VanguardVanguard Posts: 505
    Thanks for the quick fix!
    Yes, thank you so much for the fix :)
    edited October 2013
    Thanks for the quick fix. Give us a shout when it's up on the DAZ servers. I just tried her out standing next to a YT5 Julie, and the poor girl looked a bit crumpled — so I just had to use a Teen Angst pose and [removed]and put a sly/smug grin on Harleigh). ;-)
    Edit: WTH — the [removed] bit in my post was "[removed]". Never seen this before in the DAZ forums.
    Post edited by SpottedKitty on
    Edit 2: and the bit in quotes was removed again. This is very Not Good™. >:(
    ok. the Harleigh update should already be live and downloadable as the genesis download.
    As far as the other issue, sorry, can't help you with that!
    Yes we have seen this before, not at all certain what trips it, but something seems to set off an automatic filter of some sort.
  • none01ohonenone01ohone Posts: 862
    @ SpottedKitty
    Looks like it was a bludgeon free posting. Hehe.
    If it's any help, in this case the removed text string was the lowercase final word of the name of this item minus the "s" at the end, plus a space, then an open bracket. Quite how that could possibly cause a Scunthorpe Problem I have absolutely no idea at all. Would it help if I bug-reported it?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,541
    edited October 2013
    edited October 2013
    Interesting, you didn't put the "space-bracket" at the end (I can see what you had in the post in my e-bot) and this time it was changed to a full stop. (Thought it had vanished without a trace, but I finally saw it.) Weirderer and weirderer, as Alice could have said.
  • HastyDaveHastyDave Posts: 109
    I think it's the filter that strips out code or script that's tripping. I suspect it thinks you're using a CSS Expression.
    Dragging this thread kicking and screaming back on topic, I just re-installed the Genesis files and everything now works perfectly. Thanks for the quick fix. :coolsmile:
    you are very welcome. Glad I was able to help.
  • TaozTaoz Posts: 10,347
    Good point... :lol:
