Geograft not showing on Render tab
Something weird started yesterday.  I'm working on a mermaid with a geografted tail.  Normally this hides the legs and shows a tail.
For some reason, this no longer works on the render tab.  The other tabs (Actors, Pose, Lights) all work fine, and when actually rendering it's fine.  So I'm trying to figure out what got bumped on the render tab that's messing it up.
  • Richard HaseltineRichard Haseltine Posts: 111,408
    I suspect you have the Geometry Editor, Joint Editor, or Node Weight Paint Brush tools active - those make all geometry visible to allow editing.
  • Ah, that was it.  Thanks.  Thought something was broken.
