Genesis Legacy UVs Iris Problem
Hello,
 I've been using legacy uvs for my genesis but for some reason I want to change the eyes of genesis 3 to different texture from genesis 3 material but it won't let me change it all! It still have the same eye texture from m4 texture. How can I remove the michael 4 eye texture so I can use my regular genesis 3 eye texture? Please help asap.
  • Cayman StudiosCayman Studios Posts: 1,145
    You should be able to change to a Genesis 3 Eye texture by just applying the Eye Material preset in the normal way.  This will set the Cornea, EyeMoisture, Irises, Pupils and Sclera surfaces to the Genesis 3 eye texture and change the UV Set back to Base Male.  Go to the Surfaces tab and check the properties for these surfaces to see what is happening.
    It may be, though, that the morph you are using (it looks like a lizard man) has distorted the eye geometry so that the surfaces are no longer in correct relation to each other, which makes it a different sort of problem.  In your picture I cannot see anything resembling the normal eye geometry, irrespective of the texture.
  • You should be able to change to a Genesis 3 Eye texture by just applying the Eye Material preset in the normal way.  This will set the Cornea, EyeMoisture, Irises, Pupils and Sclera surfaces to the Genesis 3 eye texture and change the UV Set back to Base Male.  Go to the Surfaces tab and check the properties for these surfaces to see what is happening.
    Alright cool. Yeah I did Lizardman morph onto Genesis 3 Male so you are right about the eyes. So I hid one of the surfaces and change the sizes of the eyeballs to make it look right. Thank you for your help.
