Trouble with Etta for Edie 8 - Wrinkle Detail Missing
dracorndracorn Posts: 2,353
edited April 2019 in The Commons
When I render Etta, I don't get the deep HD wrinkles.  I'm not sure what's wrong.
My render:
The Promo:
Post edited by dracorn on
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited April 2019
    If you check on the parameters tab under the figure, under the "Mesh Resolution" section, is "Render SubD Level (minimum)" still set to 4?
    Also, under either the shaping tab or the parameters tab under... actor, I believe, is the "Etta HD" dialed to 100%? You should be able to use the "Currently Used" option at the top of either the parameter or shaping tab to quickly see what is currently dialed in.
    Post edited by AlmightyQUEST on
  • dracorndracorn Posts: 2,353
    Thanks, AlmightyQUEST .
    The answer to your questions is Yes.  Render SubD Level (minimum) is 4, and Etta HD is at 100%.  I even uninstalled and reinstalled both Etta and Edie 8.
    Still no wrinkle details.
  • xmasrosexmasrose Posts: 1,409
    How did you render? Did you use the live preview?
    Woa.  I would never have thought that the wrinkles would only show up in a full render rather than live preview.  I tested it and yep, the wrinkles are there.
    Go figure.
    Thanks xmasrose (aka tulipe) !
    You're welcome. (That happened to me too!!!!)
  • Oso3DOso3D Posts: 15,085
    The reason is that you can separately set the SubD level for viewport/regular work vs. what appears in render. And the reason for THAT is to make it way easier to pose and move things around and see what's going on without your machine trying to keep up with a hugely subdivided mesh.
    Thank you for the explanation. Makes sense of course.
    Yeah, thanks Oso3D !
