Messed up skin on interactive render
Hello there,
So, I've been doing some renders on Daz 4.11, and when rendering with Iray's interactive mode, the character's genital color is all messed up. On photoreal mode it works fine. Any clues?
Thanks!
Hello there,
Thanks!
As I recall, Interactive Mode does not support subsurface scattering, which is critical to realistic looking skin. There's a good chance that's what's causing it. You'll probably have to tweak the surface settings to remove the SSS elements and see if you can get skin that looks "good enough" for your purposes.
Many thanks! Will try it as soon as I have the time. If someone else have any other ideas, I'm all ears
