Mirroring Imported Objects
I have tried to import objects into DAZ but they are always mirrored after the import. In other words if I import a staircase model and the first flight of stairs is on the left, after importing into DAZ the appear on the right. It is just mirrored on the horizontal plane. I have tried to use the axis conversion in the import window but it does not have any effect the object still comes in mirrored from what the original was. Is there a way to mirror the object inside of DAZ after import? I have tried Hexagon but couldn't find a mirror function there either. Any info would be appreciated. Thanks
  • FSMCDesignsFSMCDesigns Posts: 12,859
    That is odd, I import .OBJs all the time and have never had them come in mirrored. I would check your import options dialogue when you import to make sure none of the invert boxes are checked.
  • kwanniekwannie Posts: 870
    I looked the and none of them are  option boxes checked, still comes in mirrored on horizontal plane. Is there a way to mirror an object inside od DS?
  • AscaniaAscania Posts: 1,857
    Scale -1.0
    Ascania.......... What does Scale do for mirroring Objects? Whicle scale are you reffering to?
    many times is you reduce the scale to the negative value, it turns the object to the negative value which basically mirrors it. Worth a try.
    Thanks!!! worked like a charm!
