Red Fox
Does anyone know how to make the "Red Fox by AM" look furry as in the promo images.
This is the best I've been able to do with it. There must be some setting to accomplish this.
https://www.daz3d.com/red-fox-by-am
You can see the first photo is mine, and looks almost hairless, whereas the second photo from the product promo looks nice and furry.
sad
  • FSMCDesignsFSMCDesigns Posts: 12,855
    3Dlight or Iray? If Iray you need the Catalyzer to make the hair display properly. https://www.daz3d.com/lamh-2-iray-catalyzer
  • vonHobovonHobo Posts: 1,715
    Thank you. It's Iray.
    I will purchase the Catalyzer. Hope it's not too expensive. frown
    It's only $7.77 so no brainer to purchase.
    I'm assuming I load the Red Fox LAMH figure and run the LAMH 2 Iray Catalyzer script on it?
    So then what is the Red Fox Catalyzer figure for?
    Sorry, I'm so confused.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    You will load the Red Fox Catalyzer figure. The Catalyzer is a plugin which will have a new panel (you can open it up from the window > panes menu at the top). Use the render option from that panel with the fox to get the iray results with the fur.
    Thanks AlmightyQUEST! That is really helpful.
    I"m purchasing the LAMH 2 Iray Catalyzer plugin tomorrow and will go from there.
