Where to download Fluidos plugin
I just purchased Fluidos and wanted to try it out. I have the props and all, but not the plugin. I checked my Product Library page, but all I have is FLUIDOS for Daz StudioContent and FLUIDOSforDazStudioTutorials. I tried to use DIM, but it just crashed whenever I try to download the file. Is there somewhere I can get the plugin files besides DIM?
  • Richard HaseltineRichard Haseltine Posts: 110,589
    Plugins do require installation through DIM (or stand-alone if supported, but apparently it isn't here).
  • Is there some way to contact the author about them?
  • LeanaLeana Posts: 13,348
    The vendor is not the one in charge of downloads, you would need to open a ticket to Daz support (Help > Contact us >Submit a Help Ticket in the store here)
    Alright. I'll do that. Thank you. ^^
  • To anyone having this issue, here's how I fixed it. The reason DIM kept crashing is that it was set to download into a folder in Program Files. I made a new folder in my documents, set that as the path and the install worked just fine. Thank you to all who read/commented.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    So Fluidos can't be installed manually? Guess I'll take it out of my wishlist then, bummer.
  • AlbertoAlberto Posts: 1,471
    The content and tutorials can be installed manually as usual.
    The Fluidos plugin itself, however, cannot be downloaded from the user's Product Library, but it can be installed manually if the DIM is used as a downloader:
    https://www.daz3d.com/forums/discussion/comment/3922111/#Comment_3922111
    That isn't the default setting, so it shouldn't affect most users.
    Thanks for the info, but I never use DIM
