  • 3Diva3Diva Posts: 12,058
    Perhaps Blair Hair with the opacity cutout bumped way up? :)
    edited March 2019
    If you don't mind making some adjustments - it comes with a ton of movement morphs and lots of bones for movement and positioning. You might be able to get the look you're after with some of the movement morphs and bones.
    I wasn't able to spend much time on it, but here's after a couple of minutes of moving the bones and adjusting it with the movement morph sliders. You could probably get closer if you spend a bit more time tweaking it than I did.
    Cutout opacity set to 3, X Scale (in the Parameters tab) set to -100%.
    554 x 720 - 532K
    Post edited by 3Diva on
  • L'AdairL'Adair Posts: 9,479
    Found here at Daz, I think these two also have possibilities, with some work.
    The toon character Cookie from Lady Littlefox comes with two hairs, one that might work for you, as well.
    Cookie promo image
