Aqua from Kingdom Hearts
in The Commons
Any idea what hair I could use to recreate her?
https://cdnen.samurai-gamers.com/wp-content/uploads/2019/01/04151925/Aqua-Profile-e1548224347387.png
Perhaps Blair Hair with the opacity cutout bumped way up? :)
If you don't mind making some adjustments - it comes with a ton of movement morphs and lots of bones for movement and positioning. You might be able to get the look you're after with some of the movement morphs and bones.
I wasn't able to spend much time on it, but here's after a couple of minutes of moving the bones and adjusting it with the movement morph sliders. You could probably get closer if you spend a bit more time tweaking it than I did.
Cutout opacity set to 3, X Scale (in the Parameters tab) set to -100%.
Found here at Daz, I think these two also have possibilities, with some work.
The toon character Cookie from Lady Littlefox comes with two hairs, one that might work for you, as well.
