Oops. Forgot to answer the last half of your question. You can absolutely layer these if you want. If you are using these for a character set - "by layering them " just export them together - and when you reimport, they will come in combined as one mesh. It will not add a second surface for a material node though. Just one.
@RAMWolff, if you use the Geometry Editor to rename the material surface of one of the layers before you export them together, you should get two material zones of the new object, when you import it back into Daz. You may want to rename the material zones after you import, as the process sometimes adds stuff like "Product_" to the existing zone.
@chevybabe25, I assume the above solution is fine for personal use, but is it also acceptable for someone using these as a merchant resource?
So glad you are enjoying these xyer0!!! And thanks to everyone for the previous comments. I don't know why I didn't get any emails for these posts. Strange!
Any ideas why the procedure described in the PDF to create a prop for delivering eyebrows with a newly created character won't work?
I've tried it a hundred times, but it definitely doesn't work as explained. When I import the previously exported eyebrows to attach them to the G8M, they are invisible, and the whole "hip" subtree is missing (which I assume causes the problem).
Hmm... not sure if it's related, but it looks like OBJ export seems to be broken in DS in general (I'm using the latest beta). No matter what the setting is, it always exports the UVs collapsed into one. That still used to work correctly a couple of weeks ago.
Hmm. I have no idea what the lastest build is. I try not to update too often on the newest build when I am working on things. My version is 4.11.0.383.
With that said, I can not replicate the obj export import problem at all.
Sofax after reading your comment a second time, I wonder... If you reimport the brows, and shut off g8 male in the scene tab, are they brows visible?
Nope, there is only one single node with the complete subtree missing.
What was I thinking ... I shouldn't have used the beta for this job - looks like I'll have to redo some of the work. The morphs don't work in 4.11 either. :(
EDIT: I'll take that back, my morphs do work. I didn't have the G8M node selected. :)
The eyebrows export doesn't work with DS 4.11 either. I checked the exported file in Blender, just to be sure - it's indeed just an empty vertex group. That's weird.
What a geat tip! Thanks L'Adair!
Yes! You can layer them like that with your commercial character sets as well. I think it adds more possibilities to create something truly unique :)
love the G8F brows and these look like a fantastic addition- love how many styles there are!!! Fantastic details!!!!
Always worth following anything from Chevybabe!! :)
Any word on wheeeennnnnnnn? :D
Laurie
LOL. Yes! Very Very Very Sooon :)
This has been the product I've been looking for everyday...glad it will be soon!
Thanks guys :) Feelin the love
Not too much longer to wait!!
LOL Sorel :) They are here!!!!!!!!!!!!!
Yay- and thank you!
Sitting in my cart waiting for the Bonus item to be sorted out...
Carted. YAY!
Yw :) These statements make this job all the more rewarding !!!
Ohhhhhh...my gents need new caterpillars!! They're lovely :).
In the cart they go ;)
Laurie
First thing in the cart last night. I am so looking forward to adding age-appropriate bushy brows on the old men in my runtime.
Just got these this weekend, and I'm so pleased. I have needed a multi-brow fibremesh solution for my men for so long. Thanks for making these!
I agree. I just went looking for an option and found this and then saw this thread.
Glad you like em FSMC :)
I too am enjoying and regularly using this product. Thank you chevybab25
@ Worlds_Edge
Feelin the love :)
Thanks for any help!
The subtree part will only show once you have run transfer utility. Did you run that already?
Wow. Well I hope they get that fixed soon then.
