Daz Studio 4.10 Pro Unable to save asset group
Hi,
An asset with a structure like attached image imported by OBJ,
From Flie> Save AS> support Asset> Figure / prop asset,
I registered in the attached image option settings,
When I open the registered asset from Smart Content,
What is wrong, only one group without content is registered,
It is not possible to register the entire asset including the camera.
※ I can register without problems if you register only with single object, not group.
Even if I investigate it in various ways, I am stuck without knowing the cause.
I would be glad if you could have a professor.
thank you
  • Richard HaseltineRichard Haseltine Posts: 110,929
    Figure/Prop will save only the Primary selected item. You could save them all individually, then save a Scene or Scene Subset; you could also try the Scene Asset option.
    If you want everything in the Scene pane saved you need to save either as a Scene or Scene Subset.
  • Figure/Prop will save only the Primary selected item. You could save them all individually, then save a Scene or Scene Subset; you could also try the Scene Asset option.
    thank you very much
