Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
By the way, because these "lights" are not recognised as lights by DAZ Studio, they will not light the scene in the viewport (only in the render). So if you have no other lights (nor the camera light) then the scene will look dark. In this case, use the Scene Light button for the Viewport (CTRL-L is the toggle).
Okay, What you have selected is the top level of Dome Light. Expand it. and select one of the lights underneath the Dome Light heading--then go into Lights tab.
If you look at my screenshot again, I am using a set of lights called SYSGTG Bright SuperArray, which is a preset with many individual lights. So I didn't select it in Scenes tab. Instead, I expanded SYSGTG Bright SuperArray and selected one of the lights in the set, Photometric Spot Light 1.
Why do I use the torus object? For some reason, in iray the torus gives more the type of lighting I expect when I use sphere in other render engines. Also, I'm too lazy to click "Double sided" on plane emissives.
For those that have problems with render times using the torus, try DOME ONLY rather than DOME and SCENE as your render environment.
Not saying it's the best, just saying give it a test try.
I know this already, how do you think I got them on the screen? Also, the "Apply first" icon states that it's a "visability" icon. All it does is makes the "Debug" red material go away. The light itself is still there. You must physically move it out of the scene or it will show in the render. If you try to hide it or turn it off, you will have no light in the render. I have no confusion about that part. I am somewhat familiar with primative surface lighting because I was introduced to it way back when I first started using the "Reality" plugin. I got pretty good at it to the point where Hobby World magazine, a world wide magazine, asked me to do an interview with them and it was featured in the December 2010 issue of their magazine. Here is one of the renders they wanted to show in the article. This entire render was lighted with flat planes converted into surface emmision lights. No other lights used.
All I can say, then, is that the "visibility" icon (Apply first) works just fine for me. I can have a Ghost light smack in front of the camera and it doesn't show up in the render (nor in the viewport in which all I have is an outline box).
For indoor lighting I just use whatever is required to light the scene. That could be ordinary lights, primitives made Emissive or the light fittings made Emissive.
This render uses the lights set to Emissive.
2019-03-27 12:38:14.619 Total Rendering Time: 15 hours 20 minutes 18.33 seconds
Click on image for full size.
