Set multiple hidden parameters/morphs to zero.
tapanojumtapanojum Posts: 73
Hi, I'm struggling to figure out how to set multiple hidden parameters to zero. I'm using Marvelous Designer to create morphs for clothes for specific figures. In order to do this I need to change all the parameters created by autofitting clothing to zero. I currently have to do this manually every time, which usually means up to 50 parameters being manually set to zero. Is there a better way?
Thanks
Post edited by tapanojum on
  • Richard HaseltineRichard Haseltine Posts: 108,735
    Edit>Figure>Clear Generated Morphs (with the figure not morphed).
  • tapanojumtapanojum Posts: 73
    Thanks for the response Richard. I may have been a bit confusing with my original post. Is there a "Clear Generated Morphs" option for the clothing itself? I don't want to clear morphs on the figure, just the clothing that is fitted to the figure.
    Unfit clothing and select it, use zero figure shape?
    Sorry, I meant with the clothing selected but the figure not morphed (so it doesn't generate new morphs in the clothing).
