DAZ Studio is a very entitled parent!!!
WendyLuvsCatzWendyLuvsCatz Posts: 41,842
edited March 2019 in Daz Studio Discussion
I cannot parent a figure to another figure, in place or not
use a null or group without the most bizzare results
I am stumped, Carrara, Poser or iClone don't do this
not saying it's lesser for it, it's just a superior feature I don't understand coming from softwares that don't do it cheeky
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,842
    Mrs Chow has Scaling issues in Carrara so it might be related to that and the HD morph, just guessing maybe parenting zeros the scaling not the morphs
  • Richard HaseltineRichard Haseltine Posts: 112,054
    What steps are you going through to get this?
    change parent in scene tab tried both in place ticked or unchecked and alternatively dragging onto
    it seems to behave as if conform or fit to checked but it's not
    I still think it might be a scaling thing
    Yes, but what are you patenting to what?
    edited March 2019
    the Heart of the Matter swing seat
    Remembering how to fly
    none of which are in the DAZ store any longer, were by Lisa B
    I think I have them, you were parenting Mrs Chow to the seat of the swing?
    yes and I actually found it is scaling the length of the ropes that does it
    which I find very odd but apparently expected behaviour parenting stuff to other rigged objects in DAZ studio
    just as an aside,
    this is the videoI rendered keyframing Mrs Chow unparented
    the first bit is the old Nvidia New Dawn demo followed by my animation
    took a lot more time than I expected as spent ages trying to parent the old dear in many ways before tossing in the towel
    I still wanted to solve this for future animations and if scaling things disproportionally is an issue parenting I am going to have problems
    OK, so you've more-or-less solved it?
    not sure solved is the word but gained more of an awareness of this odd little quirk of DAZ studio
    manual keyframing of everything is becoming the norm rather than the exception
    I was rather used to all the cheats I use elsewhere like target helpers, tracking, motion paths etc but admittedly scaling figures nonunifomly was something not doable elsewhere in the first place so shouldn't be surprised it affects other things
    edited January 2021
    Premier Artists who don't instance stuff but parent all their ooodles and ooodles of highpoly massive textured props in place  apologies the other option that sends it to a position deserve a special place in hell angry
  • WendyLuvsCatz said:
    Premier Artists who don't instance stuff but parent all their ooodles and ooodles of highpoly massive textured props in place deserve a special place in hell angry
    On a newish product or an old? Older items may well pre-date instancing (in which case you might want to use a script to replace the duplicate nodes with instances). Do note that textures are loaded only once, even if they are used on multiple un-instanced items.
    edited January 2021
    its not old, it's post iray and instancing  surprise
    and no the script has to reorder items the same as me unparenting everything
    these sets break apart on FBX export and often obj export too
    you cannot even use them in DAZ studio except as is because if you decide to unparent or reparent to something else it breaks
    edited January 2021
    actually I admit I may have stuffed up my terminology and must apologise
    it's not parent in place its the other option blush
    i have been using DAZ content for 11 years but DAZ studio itself not that much up until the last few years
    so yes I do find a lot of it's quirks challenging and terms confusing, I can send an accessory to any joint in iClone using attach for example and it will stay in that spot detached
    that still does not excuse the way such sets are set up
    edited January 2022
    no matter how I do this, parent in place checked or not, if I parent the doll to her hand it flies halfway across the room and rotates too
    and it's a prop (obj export/import)
    since the girl is Genesis 2, I am kicking myself for not doing this in good old predictable Carrara instead of DAZ studioangry
    it's an animation, so I already have to do several takes as no enable disable for picking the doll up using tracking or animated visibilty etc
    1920 x 1080 - 5M
    edited January 2022
    Is the centerpoint aligned with the object center?
    I would scale the doll down to 0% from frame a to frame b, and use a duplicate for the one she's picking up and reverse the scaling on it. I've found no better solution in DS. Every other method is clunky to say the least, like animating mats etc...
    Well of course you can use translation too and send it to the edges of the known universe...never to be found again...could be interesting as the doll would spin around, possibly blocking the sun, in which case we would experience a dollar eclipse...oh I'll see myself out...
    Post edited by Sven Dullah on
    edited January 2022
    it's the act of parenting thats the issue and I tried 2 dolls
    it's odd as I have parented objects before but seems somehow related to the aniblock baked to keyframes on the character which was then grouped to move her.
    anything parented to the girl behaves the same way
    other things are usually parented to a t posed figure first
    the animation itself is simply two separate clips joined which shouldn't have been an issue if the parenting in place didn't act so bizarre
  • PadonePadone Posts: 4,377
    edited January 2022
    I believe there's a misconception here. As I know it daz studio doesn't support dynamic parenting, so everything must be parented or not at frame zero, before starting the animation. Parenting an object to an animated figure could result in unexpected results and I guess it is what's happening here.
    The trick by Sven is doable in this case, then you can animate the scale.
    Post edited by Padone on
