Main menu disappeared. Not able to reset daz studio
Since yesterday I cannot see the main menu of daz studio. Only "Tools" and "Window" are visible. If I click on Window, I only see the "panes" option. All other stuff disappeared. I need the main menu, otherwise I do not know how to save scene subsets and all this stuff. Any help here?
A couple of things spring to mind ...
1) Try Alt-W (the shortcut to bring up the Windows menu, then look at teh Workspace and/or Styles options to see if that get syou something back.
2) Try running hte Update and Merge Menus script (found under Scripts> Utilities in Contnet Library
3) Try F3 (which is the shortcut for the Customise option under Windows> Workspace menu)
wow, the second option was the right one, thank you so much. You helped me a lot
for me too - t*was hard to find the right solution. There should be a shortcut for such an event ...
