General Freebie Requests
1444546474850»
  • kyoto kidkyoto kid Posts: 37,860
    ...I tried making a cone primitive and reducing the opacity however there appears to be some sort of seam or anomaly that is visible which runs the entire vertical length and is visible no matter which way I rotate it on the Y axis.
    I wish I could use the volumetric camera but because I also have a UE light the providing the basic fill light, it picks up on that as well so I just get a general volumetric fog over the whole scene. Not about to toy with UberVolume as it really slogs down the render process even worse than even the Fog Tool.
  • Chelle the CatChelle the Cat Posts: 214
    You use the Polygon Selection tool to select the polygons of the ears and then make your own material zone for them in Daz.
    @chellethecat:
    To select individual polygons and create a new surface: Tools > "Polygon Group Editor".
    In the viewport, click on one poly to select it then hold Ctrl down and select any other polygons you want (or optionally you can select with a rectangle). Right click and choose Polygon Assignment > Create Surface from Selected. Give the new surface a name. You will then see a new material zone in the "Surfaces (color)" pane.
    I'm going to give it a shot...
    Chellethecat: Are you using M4 or Genesis for the figure?
    M4
  • SylvanSylvan Posts: 2,644
    I am looking for half a face mask like that from the phantom of the opera, like this one:
    http://playinggodwithmonsters.files.wordpress.com/2013/07/phantom-eric-alws-phantom-of-the-opera-movie-19743666-1943-2435.jpg
    I found one on RDNA, but perhaps anyway knows of a free one since my bankaccount is already quite bruised from this month's sale ;)
    edited September 2013
    ...thought I could backtrack the to the original; submission in the contest thread to find the link to the beam prop I used however the search function in the forums archive is broke again and only pulls up a blank page. So I have to go through page by page.
    Post edited by kyoto kid on
    I'm not sure if this will work for what you're doing...
    http://forum.runtimedna.com/showthread.php?49378-The-2009-13-Days-of-Christmas-Giveaway-Day-8
  • StratDragonStratDragon Posts: 3,167
    I could make one in Blender using Genesis fem (I already did) but the problem is I don't know if I can redistribute it legally and I'm a hack modeler so striving for perfection and attaining it are two distinct things for me right now.
    DOES ANYONE KNOW if I can post a mesh from an existing model if I've modified it and I'm not reselling or is this against the license agreement?
    1190 x 808 - 240K
    AFAIK this is not allowed, as it would be a derivative of the original mesh.
  • MorganRLewisMorganRLewis Posts: 233
    Unless otherwise specified, I think you can assume that's against the license agreement. It's still their mesh, even if altered.
  • stem_athomestem_athome Posts: 435
    You appear to be using a copy of the actual mesh, which would not be allowed.
    You could create a new mesh and use surface alignment tools, although I have seen posts where auto surface alignment tools(shrinkwrap) are said to be disallowed.(not sure how they could enforce that, given the amount of cloths that are probably created by that method)
    For those types of models, I would use (in the modeller I have) UV Deform. I take part of the model, and use its(or create a new) UV map to deform a flat plane.
    I had a very quick play:-
    512 x 512 - 92K
    Oh wow, I am impressed by the effort you're going through!
    Feeling a bit giddy because of that, teehee.
    Gonna keep an eye out if it will work out ^^
    If you are referring to the attempt I made, that was just me playing around (I do not normally use DS/ Figures)
    The mask was made using the "Basic Male" figure, which installed with the starter pack, so I presume that is Genesis? Are you looking for the mask to fit that figure? (sorry, I know little about this as yet).
    Here is a slightly modified version of that mask I posted a pick of (obj format), import it(at 100%) onto the "Basic male" and see if it is what you want. (if it is for incorrect figure, or not what you want, let me know and I will make needed changes).
    obj file download link:- http://www.mediafire.com/?cqpsxahwh7w6kj1
    512 x 512 - 53K
    Post edited by stem_athome on
  • SteveM17SteveM17 Posts: 951
    I'm wanting to do a picture featuring a minotaur. So I need a bull head to put on Genesis/M4. A static prop would do, but movable features would be better. I've looked on ShareCG/Renderosity and not found anything.
    It will be indeed fitted onto Genesis.
    I loaded the base male and except from the minor details around the eye, the mask fits perfectly:
    2000 x 1600 - 2M
    Post edited by Sylvan on
    I made some adjustments, mainly around the eye. (and the edges of the mask, to stop the render artifacts I see on the mask edges in your image)
    Hope this is better.
    object download link:- http://www.mediafire.com/?ldubkclwa5b9gqc
    Sorry for the late reply. This post got buried under my notification ><<br /> Going to check it out and give feedback :)
    *EDIT*
    Aaand, Im back with the testrender and it looks good now the edges have been cleaned up.
    Awesome work, thanks!
    997 x 871 - 527K
  • DrekkanDrekkan Posts: 395
    I am working on an anime character I am wanting a specific unusual type hair for her which for me would be too complex to build myself as I have never tried to create hair on Daz and am told its pretty hard for a newbie plus I don’t have the time these days.
    Would anyone be willing to do it for me? I don’t mind paying as long as the work is good. Here is what I am looking for and you’ll see its beyond a newbie: http://fc07.deviantart.net/fs71/i/2011/088/3/2/kanu_unchou_3_coloured_by_den28-d3cri5p.jpg
    (the same girl only in a maid suit) http://mangaworld.ca/images/4582221152783.jpg
    the main things I would need would be: -clasp at the bottom when the hair ends
    -ability to move the hair across her left eye
    -the dark blue color
    -compatible with Aiko4/V4
    Is there anyone here who does requests frequently and would be good with this? I’d be paying via paypal as long as the price is reasonable.
    Anyone here interested or know someone on this site who does requests for money or not and would be interested? thankyou.
  • KeryaKerya Posts: 10,700
  • robkelkrobkelk Posts: 3,259
    edited October 2013
    Well, we've reached page #100. Here's a recap for the next thread (if we're splitting this one at 100 pages).
    Frequently-asked questions:
    How do I use 3DS models in Daz Studio?
    Convert them with Hexagon, Bryce, Anim8or, Blender, PoseRay, or PropViewer .
    Where can I get the freebies that used to be on free.daz3d.com?
    Nowhere, at the moment.
    How do I download freebies hosted at forumarchive.daz3d.com?
    Copy the link into a text editor, change the part that reads "forum.daz3d.com" to "forumarchive.daz3d.com", and copy the edited link into your browser's navigation box.
    Unanswered requests, by post number:
    3: a frog prop
    7, 74, 993: longer fingernail for Genesis (preferably squared)
    9: eye poses for Genesis
    25: animal-head hats
    36, 366, 800, 1030: Radii shoes, such as http://www.daz3d.com/forums/index.php?&ACT=50&fid=41&aid=2527_3xmvjrvgTYKQ7I52QrDB&board_id=1
    84: destroyable props (items with "damage" morphs, for animations)
    114: men's Victorian style Opera cloak for M4 or Genesis
    137: Emma stone for Genesis
    143: Greek-Roman styled bench or seat, or a Roman-style couch with one long reclining portion and a couple of seats
    145: US Army beret for Genesis
    154: reptile skins for Genesis/V+M+A+F 4 to 3
    156: boots like http://www.sharecg.com/v/58908/View/11/Poser/Cuff-Boots-PHF for Genesis
    157: track and field hurdle
    169: duffel bag
    190: Hooded long coat, for M4 or Genesis, like http://www.daz3d.com/forums/index.php?&ACT=50&fid=41&aid=9035_2e1KuUB7xNC8rNmpRy1B&board_id=1
    194: Puerto Rican flag texture for V4’s basicwear
    248: clock tower from Back to the Future
    261, 824: F-150 king cab monster truck, rigged
    279: fantasy skins for v4 or m4 - rocky skin textures or lizard type
    285: courthouse, courtroom and the natural innards
    310: Kate Bekinsale for V4
    321: Angry Birds and Green Pigs
    348: Hercules Plane or any sort of plane that would have dropped paratroopers into action (no, there isn't one on the free Aircraft list)
    401: V4 fit for the Koz Long hair
    431: Halloween "monster" costumes for Genesis male and child characters
    503: double-barreled shotgun
    505: sneakers for V4, and a beard for M4
    509: stadium with full oval running track
    510: "the Bravestarr character Vipra"
    537, 1121: realistic police uniforms and police car
    545: gentleman’s smoking jacket or short bathrobe for Michael 4
    551, 652: face morphs of Tom Baker, Christopher Eccleston, and Billy Dee Williams for Michael 4, and Bea Aurthur for Victoria 4
    555: Sixus1 "Draconis Rex" poses
    556: modern or near-modern classic firearms (assault rifle / submachine gun / pistol)
    566: firefighter clothing for M3/M4 V3/V4 & A3/H3
    568: walrus tusks
    569: elephant head (and maybe body) morph for Genesis
    592: frameless sunglasses, like http://quantumpromo.mwrc.net/images/dyn/sitemin_file2.php/product_images/58985/image/Ansi+Classic+Black-Gry+Flash+Silver.jpg
    619: poses where the characters showcase products
    621: adjustable (through morphs) spotlights (actual models that I can place a DAZ light inside), with brackets for a ceiling or wall
    632: baby blanket shell for MilBaby3
    653: Santa suit for Genesis
    675: Army-style canteen
    705: interior of an Indian palace (could be a back wall)
    707: Trapper/Russian hats for M5
    709: steampunk ankle boots for genesis
    747: Charlotte Gainsbourg look-alike
    750: Kharma look-alike
    760: female body morph for the Gruggle Monk
    800: Barsoomian add-ons for M4, and Barsoomian creatures
    817: coin purse/pouch kind of thing that I can sit on a table
    836: wristwatch that will fit V4 - preferably one that looks like one of those “tactical” Ironman or G-Shock watches made out of matte black plastic. Also a neckchain with ID tags
    860: huipil dress for M4/H4, V4/A4 or Genesis, Central Asian clothing such as http://www.thelovelyplanet.net/wp-content/uploads/2012/08/traditional_kyrgyz_dance_Go.Live_.Serve_..jpg
    861: chest-spandex type morph for V4 Elite Utopian
    869: more modern version of Nanoha's "barrier jacket" dress from Magical Girl Lyrical Nanoha ( http://web.archive.org/web/20071107041816im_/http://xposer.org/hosting/216352465_21.jpg is no longer available, http://animeartbooks.net/series/114-magical-girl-lyrical-nanoha/ has more reference images)
    911: library interior
    917: diaper for Genesis baby
    922: Dorothy Gale (Judy Garland) morph for V4.2
    972: fantasy or medieval backpack
    989: The eagle head/feathered headpiece for Zoar, Sorceress of Greyskull from the 80’s He-Man cartoon
    1002: industrial shop lamps, photograpy studio lights
    1007: this V3 headpiece for V4 or Genesis: http://www.daz3d.com/forums/index.php?&ACT=50&fid=41&aid=63369_qt3EgudCXekR4hJ43jSw&board_id=1
    1047: "modern" typrwriter
    1070, 1312: Kataginu kamishimo for M4 or Genesis, like http://www.shop-japan.co.jp/shop/image/kamishimo-9682.jpg
    1072: Bubbleship form Oblivion
    1084: commoner’s deel (traditional Mongolian outfit) for Genesis
    1085: BVH files for the T-Rex or any dinosaur
    1111: Gina Lollobrigida for V4
    1154: vintage band t-shirts and grungy/worn t-shirts for Genesis or M4
    1155: butterfly sword
    1164: Abandoned modern laboratory/building, etc like one would see in Resident Evil or similar movies/games with dirty floors and blood stains, papers everywhere, etc.
    1189: nun’s wimple, like http://tardis.wikia.com/wiki/Sisters_of_Plenitude
    1198: old clothes for an old m4 man…Hobo, tramp, ripped, dirty looking down and out
    1203: closed-toe, flat shoes (i.e. ballet slippers or loafers) and/or boots for Luke or Laura 3
    1211: swimsuit with Stephanie 4 morphs
    1214: below-the-ankle socks for Genesis
    1279: footprints in snow for DS3
    1281: satchel like the one Indiana Jones used
    1282: rabbit-face morph, and rabbit ears and feet, for Genesis
    1288, 1316: Allison Scagliotti morph for Genesis, hair like Allison Scagliotti's character in Warehouse 13 for Genesis
    1301, 1327: cyber or robot dragon (cyborg, not fully-mechanical)
    1305: Chinese weapons (Liuyedao, Guan Dao/ Kwan Dao/ Kuan Tao, Chinese spears), food (Ginger root, durian, lychees, a blueberry, foxtail millet plant), anything Mongolian besides Yurts and “Mongolian BBQ”, roadkill flattened in the middle
    1311: Blues Brothers suit with shirt and tie for M4 and V4
    1319: Gelfling from Dark Crystal morphs for V4 - hand morph for V4 to give her only 3 fingers and thumb, foot with 4 toes, neither with a "digit chopped off" look
    1320: hand air-pump like http://img0104.popscreencdn.com/157226328_vintage-hand-air-pump-lot-bicycle-automotive-truck-car-.jpg , wheeled hotel-type laundry hamper like http://www.medical-supplies-equipment-company.com/files/media/images/Industrial-Laundry-Cart-1.jpg
    1323: arm and hand poses for V4 playing the harmonica from http://lab108.x0.com/lab108/inst.html
    1324: 80’s punk rock denim jacket
    1356: leg calipers (braces if you prefer), the sort that they used for polio victims
    1363: treasure pile
    1377: two-man saw
    1379: British Army officers and battle dress uniforms of World War 2 for Genesis male and female
    1393: pack saddle for donkey
    1432: a set that loks like Elvis' Vegas outfits, for M4
    1453: male body hair presets for LAMH
    1454: a shortie heeled boot to match with the free magus legging mesh, for Genesis
    1469: fur "standing up" for MilCat
    1482: bull/minotaur head for Genesis or M4
    Post edited by robkelk on
  • DollyGirlDollyGirl Posts: 2,565
    Kerya said:
    Thank you Kerya.
  • Eustace ScrubbEustace Scrubb Posts: 2,649
    #25 is at ShareCG. OBJ format.
    #84 needs to be more explicit: what sort of props, and what sort of damage?
    #145 is answered by Wilmap's Beret.
    #348 (aircraft for paratroopers) might be solved with a CH-47 Chinook. Unless, of course, they need a C-47. 3DS format.
    #555 is fulfilled by the seventh and ninth entries here. Wayback Machine.
  • srieschsriesch Posts: 4,239
    836: ... Also a neckchain with ID tags: http://www.renderosity.com/mod/freestuff/details.php?item_id=71405
    1469: fur “standing up” for MilCat (to answer my own question): http://www.renderosity.com/mod/freestuff/details.php?item_id=15231
    Kerya said:
    thx but its still wayyyy too short.and doesn't have the clasp at the end.
    Hmmm - do you have a modeler with which you could make the hair longer? and for the clasp I would just use a cylinder primitive parented to that part of the hair ... (there is a blue texture in the textures folder)
    I would take a shot at asking the Look at My Hair gang to see if anyone of them would be interested in making you a preset. The reader is free and if you have the preset then you can load the hair onto your subject. DAZ Member beloveddalleli is real good at creating toon type hair. She is Alia on the LAMH website. You can see her work and download some of her presets here. You can search the forms for various Look At My Hair threads.
    Do you know where they are? I did some searches here but found nothing. Is there a main thread or something they hang out at where I could go ask them? thx.
    You should be looking for Kendall Sears or Alessandro_AM. Start with this thread
    http://www.daz3d.com/forums/discussion/14818/P690/ and from there they can direct you to other threads. I did not see any great activity on DAZ but they are gearing up for the next version of LAMH. They have a web site www.furrythings.com
  • HunterDroidHunterDroid Posts: 1
    I've been searching for models of the Apollo, Gemini, and Saturn 5 rockets of the 60's and 70's. Can someone help me out? The Moon Buggy would be good also.
  • edited December 1969
    i'm requesting a decent pig morph, or boar teeth morph, for M4. I'm on a bit of a Star Wars kick, and I want to try my hand at making M4 into a Gamorrean, and while I've got most of the body looking decent, the face needs a bit of work, especially with the teeth.
  • Faeryl WomynFaeryl Womyn Posts: 2,460
    For request #1 the frog, you can find one here and some are free...
    http://www.turbosquid.com/Search/?keyword=frog&sort_column=A5&sort_order=asc
    edited October 2013
    Once the current government shutdown in the USA is resolved, check this site:
    http://www.nasa.gov/multimedia/3d_resources/models.html
    I recall seeing a Gemini capsule there, at the very least.
    Edit: Just thought to check the Wayback Machine - they have the page at http://web.archive.org/web/20130425051111/http://www.nasa.gov/multimedia/3d_resources/models.html
    It's very slow, compared to the usual NASA site, but they do have a Gemini capsule, a "Gemini spacesuit" static character, an Apollo Lunar Module, and a Saturn V booster. The spacesuit is OBJ format; the other three are 3DS format.
    (They also have Mercury capsules, a "Mercury spacesuit" static character, and a Viking lander. No Moon Buggy, though.)
    Thread Continued Here
    Post edited by Chohole on
