issues with Fantasy Skins for G8 - Error opening file
Get error opening file.  Checked the log file and see the following:
2019-03-02 12:40:05.173 E:/DAZ 3D/data/cloud/1_59065/people/genesis 8/materials/fantasy skins/fs 01 with sss/fsg8 01c strong blue green.duf (1,1): Syntax error - expected '{' or '['
2019-03-02 12:40:05.173 Error reading file, see log for more details.
2019-03-02 12:40:11.563 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
Have installed via SMART CONTENT and manual download.
Any thoughts?  Thank you.
  • V3DigitimesV3Digitimes Posts: 3,465
    This was an issue coming from the way the Daz Connect Package was created. It should be solved now.
  • TojiroTojiro Posts: 95
    Hi V3Digitimes, I just got the Fantasy Skins product (great stuff btw, I'd highly recommend to anyone on the fence about buying it) and I was trying to tinker with a way to make silver bodypaint.  Something similar to https://www.daz3d.com/silver-textures-for-v4. There isn't a white or grey SSS Preset, and the Flakes Effects just kind of give it a white sheen.  I tried putting a desaturated base map on but it it didn't really work right.  Can you recommend a good way to go about this?
  • Cake OneCake One Posts: 383
    Thank you Banpei :)
    I would try to do that by using white flakes (or greyish) on one of the black skin preset, then play with the intensity of flakes to see how it goes. I would then add some top coat, trying different color and different presets until it fits my needs.
    I would have gladely given it a try but i'm currently struggling with my machine who dropped both of my GPUs so until i fix everything, i can't render for the life of me :/
    When i fix it, i will give it a try if you haven't found yourself :)
