Thimble .obj Model Request
MJ007MJ007 Posts: 1,716
edited March 2019 in The Commons
Hello good people... is there someone out there willing to create a thmble prop for me like the one shown?  My only request is that the "top" part is flat so that it could sit flat on its top or bottom.  Could really use it for a personal project I am working on.
If someone knows of one out there they could direct me to, that works also.
-MJ
Post edited by MJ007 on
  • I’ll give this a shot. I’ve just gotten back into modeling and starting slow with smaller props like these types of objects.
  • MJ007MJ007 Posts: 1,716
    Great!  Thanks!
    -MJ
  • Well I know now what not to do :)  While actually pretty simple to model this with Cinema4D's volume builder, the resultant OBJ file was massive (9 MB).  Basically a very high-res mesh with all the indentations as part of the mesh.  Let me see if I can create some simplified geometry.  To get all the dimples, you'll probably be better off experimenting with bump or normal maps.  Having said that, I'm not yet skilled enough to create something properly UV-mapped for applying a texture.
    I saw this but u get an error when u try to download it.
    -MJ
    If you can get the shape right, i can prolly do the rest with a bump/displacement map and diffuse settings.
    A texture prolly isnt necessary.
    -MJ
  • Charlie JudgeCharlie Judge Posts: 13,425
    -MJ
    For the last couple of days ShareCG has been having problems with a lot of their downloads. Hopefully, they will get it fixed soon.
  • barbultbarbult Posts: 26,608
    AllenArt has a beautiful new pincushion on ShareCG, but it won't download either. I can't get anything to download from ShareCG.
    edited March 2019
    If ur referring to the red one with the pins, it did for me just fine.
    EDIT:
    As did the thimble!  WooHoo!  Lets see how it works.
    -MJ
    EDIT:
    -MJ
    Tea! It looks like it was working againg I was now able to download the thimble.
    edited March 2019
    Thimble.obj doesnt work so hot.  Cant scale it properly without it tearing or warping.
    Ah well...
    -MJ
    edited March 2019
    MJ007 said:
    Thimble.obj doesnt work so hot.  Cant scale it properly without it tearing.
    Ah well...
    -MJ
    I'll give a thimble a shot, as long as you don't need it right this minute LOL ;)
    Hubby's birthday is tomorrow, and pets go to the vet Monday, so probably won't be doing much until after that. Of course, you never know with me. I'm such a nightowl ;)
    Edit: one thing though - you use a VERY old version of Daz Studio if memory serves and I use the latest. I guess I can give you the wavefront object tho. Is that what you were wanting?
    Laurie
    Post edited by AllenArt on
    edited March 2019
    So, this is what I have so far....
    The uvs are pretty flat and the object and .mtl file top out at 1.4 megs.
    If ya want it let me know. At any rate, I'll probably "Iray it", dome the top and drop it in my freebies. Will go well with the pin cushion and safety pins I released recently ;).
    Laurie
    599 x 714 - 114K
    edited March 2019
    Laurie
    That is perfect especially if i can scale it along the various axis to get the exact shape i need.
    And you are correct, i still use DS2.3 so i only need the wavefront object.
    -MJ
    edited March 2019
    If ya want it let me know. At any rate, I'll probably "Iray it", dome the top and drop it in my freebies. Will go well with the pin cushion and safety pins ;).
    Laurie
    Laurie
    That is perfect especially if i can scale along the various axis to get the exact shape i need.
    -MJ
    K, I'll need to get it to you somehow. Can I email it to you? You could PM me your email address :). It's small enough for me to send (and hopefully small enough for you to receive). The zipped files are just over 300K.
    Laurie
    THIS ABSOLUTELY PERFECT!!!
    THANK YOU!!!
    -MJ
    smileyyes
    For everyone else....soon™
    Laurie
    800 x 800 - 750K
    Laurie
    Pretty dope
    MJ007 said:
    Laurie
    Pretty dope
    Iray makes it look good ;)
    Laurie
  • caravellecaravelle Posts: 2,706
    Thank you very much; this thimble looks great! I'm off to grab it ;-)
