[Released] Oso Janus Doubled Sided Shader Merchant Resource for Iray
2»
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    No on translucency, see the posts just before yours. And a bit further up is a screenshot of parameters.
  • SzarkSzark Posts: 10,634
    edited March 2019
    I saw those but wasn't sure if it was the full compliment and if it is, well that is a deal breaker. Looks like I will have to add backfaces to the existing shader network.
    Post edited by Szark on
  • Oso3DOso3D Posts: 15,125
    Good luck; I found it impossible to play with backfaces and have translucency. If someone finds a way to do it, that would be welcome.
    LOL Ok you have SSS Reflectance tint shown so am I correct in assuming there is Thin Wall and SSS settings?
  • I find myself grabbing a rather a lot of your stuff to play with the last several days... :)
    Aside from subsurface scatter (unfortunately) this would be great for the darker/waxy side of a leaf and the more pale, non-reflective underside of it, right?
    Yes!
  • shinteo5shinteo5 Posts: 10
    edited February 2020
    It doesn't seem to work for me.
    Edit: Nevermind. I'm an idiot and didn't realize that you need to render it to show up.
    1471 x 897 - 169K
    Post edited by shinteo5 on
  • DripDrip Posts: 1,270
    Does anyone else have an update for this in DIM that continuously fails to download?
  • DaventakiDaventaki Posts: 1,624
    edited March 2020
    I got the update, it worked fine on my end.  Whispers: May not be but check your disk space, I am embarrassed to admit ive done this a few times and was mad because I couldn't get the darn things to download........
    Post edited by Daventaki on
    I was worried about that too, but 536GB free, so it should fit easily. I think I'll just try a manual download, and see if that makes the problem go away.
