Eyes Point At the Bouncing Ball?
KickAir 8PKickAir 8P Posts: 1,865
edited September 2013 in Daz Studio Discussion
Back in the Mil4 days there was this trick of using DAZ Studio's "point at" feature (usually at a null or low-poly primitive for easier fine-tuning) to make a figure's eyes look naturally in the needed direction. This stopped working well with Genesis -- the eyes still tracked fine, but the appropriate eyelid morphs didn't follow the way they did with the Mil4s. G2F being touted as such an improvement over Genesis I was hoping we'd get this back, but as can be seen from my V4-G1-G2F tests below? No dice.
I don't remember hearing any complaints about this -- have I been missing them, or is this not as useful a feature to others as it was to me? 'Cause I'd really like to have it back.
Post edited by KickAir 8P on
  • DigiDotzDigiDotz Posts: 515
    There is a script to do that at http://www.sharecg.com/v/67748/view/8/Script/PointAt-Fixer-for-Genesis-eyes
    ..someone mentioned that it works on g2f if you change the object name in the scipt to Genesis2Female
    Post edited by DigiDotz on
  • KickAir 8PKickAir 8P Posts: 1,865
    Yeeps! Sorry, didn't get a reply-notification on this -- thanks!
    I was hoping for a DAZ-side solution, but I'll take what I can get. Appreciate your help!
  • galactica1981galactica1981 Posts: 1,251
    Where should this folder be installed? Do I simply drop it in My Library? I did that and it doesn't seem to be working.
  • Richard HaseltineRichard Haseltine Posts: 108,998
    Drop it in My Library, perhaps in the Scripts folder, then find it in the Content Library pane and double click to apply. You can also right-click on it and select Create Custom Action to add it to your Scripts menu.
  • Miguel2121Miguel2121 Posts: 27
    Is there any solution for seeing the correct eyelid movement after applying this script during the camera movement, or I have to apply this script after every camera movement?
    I mean, I would like to see an eye and eyelid movement that Victoria 4 has, but even with this script the setup of the desired movement is somewhat cumbersome. Though it is possible that I did something wrong with the installation...
