tip : improve bump and displacement renders by using 16-bit versions of your maps
mCasualmCasual Posts: 4,607
most images use 8 bits per color channel, which gives us 256 grayscale levels.
when applied to the Displacement channel in daz studio and software-rendered, we get fig 2.
by converting this gray map to a 16-bit tiff file and blurring it a little we can get rid of the staircases. ( fig 3 )
it's not as good a solution as having a native 16-bit map but i think it helps
the freeware way is :
download and install imagemagick from www.imagemagick.org
what you want to download is called the "binaries" not the "sources"
versions that do support 16 bit images are labeled "Q16"
write a batch file like this using a text editor like notepad or wordpad
c:\imagemagick\convert yuppp8.png -depth 16 -blur 16x16 yuppp16blurred.tif
save it as "convertme.bat"
run/execute it by double-left-clicking on "convertme.bat" ( in Windows Explorer )
it converts the 8-bit png to 16 bit and blurs it then saves it as yuppp16blurred.tif
note that the way "convertme.bat" is written, it takes for granted that you installed imagemagick in your c:\imagemagick\ folder
and it takes for granted that yuppp8.png is in the same folder as "convertme.bat"
note: when i tried with a source image being a JPEG file, imagemagick refused to do it
so i converted my jpg into a png image using paintshop
but this would probably work too:
c:\imagemagick\convert yuppp8.jpg yuppp8.png
it works in many modern 3D softwares
in Blender-Cycles this allowed me to get Fig 5 instead of Fig 4
Post edited by mCasual on
  • SzarkSzark Posts: 10,634
    LOL I was waiting fo the rest to appear before commenting...nice tip thank you very much for shar................ :P
  • mCasualmCasual Posts: 4,607
    edited September 2013
    3x3 blur instead of 16x16
    i'm starting to think that it's the JPEG compression that produces the initial staircases
    ...nope, i did a test, loaded the jpg in a paint program, blurred it, saved it as an uncompressed 8 bit TGA
    and the resulting render had staircases/artefacts ... so the 16-bit conversion is necessary
    1920 x 1080 - 277K
  • V3DigitimesV3Digitimes Posts: 3,492
    Wow! Thanks for this tip!
    here i used a Daz PointLight to render something that i can use as a displacement map
    the 16-bit version ( smooth ) was blurred with a 3x3 filter
    c:\imagemagick\convert bliprender.tiff -depth 16 -blur 3x3 bliprender16bit.tif
    fig 5 - with tiling, there's artifacts that become apparent , they'd probably me solved be reducing the Shading Rate
    part of the problem may be the use of refractive glass
    1920 x 1080 - 862K
    1280 x 720 - 134K
    546 x 900 - 69K
    800 x 450 - 246K
    1920 x 1080 - 379K
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    Can't you do the conversion and blurring with tdlmake and get same results?
  • SylvanSylvan Posts: 2,719
    edited October 2013
    How does this workout in Luxus?
    I know that Reality has some problems with the bump and displacement maps within DAZ (they have to be dialed to 0 and later changed withing Reality itself).
    Will it still work out?
    Post edited by Sylvan on
    probably but you'll have to figure how to ask tdlmake to do it
    http://www.3delight.com/en/uploads/docs/3delight/3delight_12.html
    i dont really know much about luxus, reality and luxRender
    but i saw a few minutes ago luxRender can juggle with EXR images so it must not be afraid of 16 bit per channel images
    if luxus refuses to play with 16-bit tif images you could try png or tga as the output format of the convert&blur; batch file
    also note that in my example i use a 16x16 blur filter which is way too soft except for huge images, so you could use 4x4
    well thanks to you I am now making all Bump and Displacement maps in 16 bit Grayscale as Tiff's. Nice and smooth results now. Thank you so much again for this tip Casual.
  • 3dcheapskate3dcheapskate Posts: 2,732
    Like many of the best ideas this one's simple, obvious (once it's been pointed out) and makes one think "now why hadn't I thought of that before?" Many thanks Casual!
  • MarshianMarshian Posts: 1,465
    edited December 2013
    This post helped a lot! However I'd like to add that even with displacement images at 16bit / grayscale artifacts may render if the image has extreme contrast (lots of black and very light areas). I blurred the images a bit and toned down the contrast to more of a medium-range grayscale and the artifacts disappeared.
    It's interesting that turning progressive render off and on affects displacement.
    It's interesting that I can go to high numbers for maximum displacement but dropping the minimum to low (below -4) starts to show artifacts.
    It's related to reflections somehow, that I'm using Ubersurface, and that my terrain was exported from Bryce.
    Post edited by Marshian on
