Blurry Nvidia Iray Renders
I recently started having a blurry render problem. My render settings are set to [defaults] and I used to have good renders. I don't understand please help, Thanks!
The images are quite small, but I'm not sure what you issue is as they don't look blurry.
Do you cameras have depth of field set to On?
I guess that's because you have low resolution!
Go to render settings, general, and there you can set the wanted resolution. I use 2560x1440, then I downscale to 1920x1080, so that I lose some noise.
I would do two things: in the Render Tab> middle tab Render Editor, set the Render Dimensions to a larger size as mentioned above, and set the Pixel Filter to Mitchell and 1 (RenderTab>Render Editor>Filtering> Pixel Filter)
I had a similar problem. Turned out depth of field was set to on in the camera properties.
