Blurry Nvidia Iray Renders
I recently started having a blurry render problem. My render settings are set to [defaults] and I used to have good renders. I don't understand please help, Thanks!
  • nicsttnicstt Posts: 11,715
    The images are quite small, but I'm not sure what you issue is as they don't look blurry.
    Do you cameras have depth of field set to On?
  • LenioTGLenioTG Posts: 2,118
    I guess that's because you have low resolution!
    Go to render settings, general, and there you can set the wanted resolution. I use 2560x1440, then I downscale to 1920x1080, so that I lose some noise.
  • nemesis10nemesis10 Posts: 3,996
    I would do two things: in the Render Tab> middle tab Render Editor, set the Render Dimensions  to a larger size as mentioned above, and set the Pixel Filter to Mitchell  and 1 (RenderTab>Render Editor>Filtering> Pixel Filter)
  • pbaddhanpbaddhan Posts: 139
    I had a similar problem. Turned out depth of field was set to on in the camera properties.
