Bo Staff Blur Prop
MJ007
Is there one that can be used in DS2.3? Preferably FREE.
-MJ
Post edited by MJ007 on
MJ007
-MJ
Don't know of any off hand.
Do you need a 3D model or would a render on a plane work? (like how they often do the helicopter rotars blur in DS)
The latter is easy enough to make in GIMP / PS - I could probably do one today.
The former I couldn't do.
That just might work great, The Bo Staff is a freebie on Rendo called Gabrielle's Fighting Staff. Im using the staff with only the wood portion of staff showing. Everything else is turned off.
I really appreciate your assistance with this!
-MJ
Don't thank me yet - my efforts may still suck LOL
I've downloaded the staff - will give it a try in a few minutes (baby daughter permitting ;) )
OK - I did a couple of versions - one is a 360 and the other is partial.
Attached below along with example pics (with original Toon Boy Sam because I hadn't used him in a while). All rendered in 3DL because I know you use that.
Feel free to critique it and ask for improvement (not promising I can do it but if I can, then I don't mind).
Simply add a plane primitive and use these jpgs in the diffuse and opacity channels (adjust glossiness/specular if needed), resize and position and away you go. It's not perfect as there's no arm/hand blur to go along with it but hopefully it can work for what you need.
I will give it a try asap... thank you!
-MJ
Speaking of which, does DAZ have any plans of implementing Iray's motion blur?
Could this work?
https://www.daz3d.com/motion-blur-for-iray
Nah. I dont use DS4.10.
-MJ
Works pretty good for me. Thanks!
-MJ
Glad to hear it :)
