Daz carga pero no presenta nada en sus cventanas de menu
Tenía cargado Daz en mi Mac pero de un momento a otro dejó de aparecer al menú en las ventanas, solo aparecen grises las letras y no me deja seleccionar nada ni en las ventanas ni en el programa, ¿a alguien le ha sucedido, cual es la soloción? ya lo cergué de nuevo varias veces y el resultado es el mismo, ayuda.
  • NorthOf45NorthOf45 Posts: 5,898
    Using translation software... (and a little editing).
    Heading and original question:
    Daz loads but does not present anything in its menu windows
    I had Daz loaded on my Mac but from one moment to another the menu stopped appearing in the windows, only appears as gray letters and will not let me select anything in the Windows or in the program. Has it happened to anyone, what is the solution? I already loaded it again several times and the result is the same, help.
    Maybe someone knows something. I have never seen or heard of this problem.
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Check to see there isn't an off-screen dialogue box open, or one behind the main window. On Windows I'd try hitting Esc a couple of times, I think you can do the same on Macs.
