mcjAddStretchMorph: add stretch morphs to anythink Updated and Safer 2019
mCasualmCasual Posts: 4,607
edited March 2019 in Freebies
here: https://sites.google.com/site/mcasualsdazscripts4/mcjaddstretchmorph
mcjAddStretchMorph IS updated upgraded and made safe for use on subdivided geometry - in this example it was used to stretch the chair legs and back rest
versions before V4 : creating a morph on a subdivided surface could render the scene file un-openable
something very similar to this can be done using a d-form
but this script does the job quite fast and easy
History
v4 - February 28th 2019 - 1036 PM - creating a morph on a subdivided surface could render the scene file un-openable
v3 - September11th 2015 21:58 - Major update, added an Append To Morph" and a "Remove from Morph" button
v2 October 7th 2014 1252 pm - Added the 'scale' effect. Now allows the non-zero-posed objects to receive the morph
v1 - October 5th 2014 12:33 pm release
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited October 2014
    note that i used a script like that to create the morphs for upcoming free mechanical parts
    i will probably post the script that was used to make the hole diameters morphable
    1920 x 1080 - 665K
    1920 x 1080 - 781K
    a few seconds ago, the thick yellow cylinder was a daz-studio-primitive-torus
    1920 x 1080 - 492K
    edited October 2014
    Figure 2
    i will add this feature:
    if instead of a Plane, the "stretch director" is a Cube
    then, only the vertices inside the cube are part of the morph
    Figure 3 - a third mode, with a cube to select the vertices to morph and a plane gives the displacement direction
    ( for cases where it would be hard to fit both functions in the cube )
    Figure 4 - when using the 3-objects mode, the script detects the role of each node based on their labels
    No equivocal situations are allowed,
    so your field/domain node label must include the word 'cube',
    your director object label must include the word 'plane'
    and the label of the object that will receive the morph must not include the word 'plane' nor the word 'cube'
    1280 x 720 - 159K
    1356 x 766 - 122K
    395 x 324 - 33K
    1280 x 720 - 298K
    768 x 640 - 480K
    edited October 2014
    making little adjustments to make it work in DS 1.8
    a stretched cone
    dang it there's no multMatrixVec function in DS 1.8 ... but there may be an equivalent
    DzVec3 multiply (DzVec3 vec)
    yay it works, it was essential for weirdly rotated and scaled bounding boxes
    works in 2.3 too now
    but notice that the was DS4 displays the local axis is more practical for this
    and it works in DS3.1 without change ( since we only "touch" the vertices and not the faces )
    924 x 556 - 66K
    818 x 680 - 58K
    816 x 686 - 59K
    1200 x 1000 - 117K
    1096 x 739 - 55K
    edited October 2014
    900 x 506 - 332K
    600 x 600 - 74K
  • Miss BMiss B Posts: 3,071
    Oh this looks interesting. Even if I don't "need" to stretch a prop, i'll sure have fun playing with it. :coolsmirk:
    created a plane
    positioned it across the dress hip section
    selected the dress hip
    selected the plane
    ran the script
    1 second later badabing stretchable dress :)
    900 x 506 - 319K
  • atticanneatticanne Posts: 3,009
    Yay! I've got to try this and have downloaded it. Thanks for all you give us.
    Casual said:
    created a plane
    selected the plane
    ran the script
    Ohhhh, I might just have to try that. :coolsmile:
    edited October 2014
    NOTE:
    For now, before using this script,
    the object that receives the morph must not
    have beeen moved from the position/orientation
    it had when loaded
    the update (tomorrow?) will have a
    displace and a scale mode
    and you wont have to zero-pose the object receiving the morph
    because the script will do all the 3d math-acrobatics needed
    1256 x 568 - 98K
    edited October 2014
    the upcoming update will be able to
    add morphs to a rotated/scaled object
    whereas the first version only worked on non-rotated/non-scaled objects
    figure 2, by placing the push-direction plane properly, you will get bi-directional morphs
    figure 3, moved the push-direction plane down, so now all the selected vertices are push-scaled in 1 direction
    900 x 900 - 413K
    900 x 900 - 332K
    1602 x 894 - 239K
    900 x 900 - 374K
    Update - Version 2 - Update - Version 2 - Update - Version 2 - Update - Version 2 -
    The script now works on props that are not at their initial position and orientation
    There is now a 'scale' option
    instead of just pushing the vertices away as a group,
    the selected vertices positions are scaled.
    if you use a direction-plane, the origin of this magnify effect has its origin at the plane location
    if you only have a domain/field cube, then the bottom of this cube is the origin of the scale effect
    480 x 381 - 37K
    edited October 2014
    real-life use, slightly de-cheekifying high waist pants
    hat was done very quickly in the old mcjLathe script
    the OverTheKnee boots for Aiko3 are free on my site
    1280 x 720 - 304K
    1280 x 720 - 304K
    been using mcjAddStretchMorph a lot thses days
    one of its strong points is that i can apply it to a posed/moved figure
    all this can be done with d-Forms, but i find mcjAddStretchMorph's "hard" fields to work well on low-poly figures
    1920 x 1080 - 670K
  • MilosGulanMilosGulan Posts: 1,987
    Looks great i will have to try it too.
    edited April 2015
    just promoting this script some more because i use it so much since its creation
    also see mcjAddRadialMorph ( google it)
    in just a few minutes i created 3 scaling morphs for the short's 3 bottom rows of vertices
    using very careful methods one coud add fabric tension wrinkles on the front of the shorts
    but personally i used a grayscale displacement map and mcjElevate to do it
    1280 x 720 - 356K
    1108 x 614 - 84K
    1108 x 615 - 130K
    1109 x 616 - 216K
    1114 x 624 - 194K
    edited September 2015
    mcjAddStretchMorph and mcjAddRadialMorph will be updated very soon
    two new functions will be added
    there's the "Remove from Morph" button, which removes the selected vertices from the  named morph
    and there's the "Append To Morph" button which is all explained in the image below
    when it's ready i will post it on the release page , and announce it here
    800 x 800 - 173K
    still not used to the new comment system
    - UPDATE - - UPDATE - - UPDATE - - UPDATE - - UPDATE - - UPDATE -
    if you have trouble downloading from my google attachments, here's a direct link to the zip file
    https://sites.google.com/site/mcasualsdazscripts4/mcjaddstretchmorph/mcjAddStretchMorph.zip?attredirects=0&d=1
    New in version 3
    If your target object does have a morph named, for example "Stretch" and the current specified morph name is "Stretch"
    then using the "Append To Morph" button will add the selected vertices movements to that existing morph
    then using the "Remove From Morph" button will remove the selected vertices from the existing morph
    900 x 900 - 256K
    edited March 2019
    888 x 888 - 159K
    Post edited by Chohole on
  • Silver DolphinSilver Dolphin Posts: 1,638
    Nice script! Thank you
    welcome it's so easy to use that i tend to use it often to stretch/shorten dresses or add adaptability to furniture and props https://www.daz3d.com/forums/uploads/thumbnails/FileUpload/ac/2ff1423371fcada23d0aa6c0053b06.gif
  • chris poolechris poole Posts: 126
    Hi mCasual, would you say this would do Squash and Squeeze as well, especially to a torso or other body parts, or would that be too much to handle?. Thanks in advance.
    edited March 2019
    you would have to show me visual exanples if what those 2 effects mean, i have other scripts
    https://sites.google.com/site/mcasualsdazscripts4/mcjaddradialmorph
    that create morphs. some allow chosing parts of the object some dont
    edited March 2019
    Sorry for the late response. not sure how to get notifications?
    This is what I'm trying to achieve, non of the horses enable this from my understanding and without it they look stiff. Thanks
    edited March 2019
    maybe you could Z-Scale the Abdomen and/or chest of the horse using the Z-Scale sliders in the parameters tab
    maybe alo mcjBend could be used to create a better curved-back than the abdomen/chest Bend controls
    https://sites.google.com/site/mcasualsdazscripts2/mcjbend
    602 x 658 - 70K
    That should work, perhaps some dforce applied might be possible? Thanks for your input and great scripts.
