Cart doesn't work
caravellecaravelle Posts: 2,755
Today I tried to buy some festival items, but whatever I do, my cart stays 'empty'. If I try to put the same thing into the cart again, I am told that the maximum quantity allowed is 1...
  • VanguardVanguard Posts: 505
    Try this:
    1. Log Out
    2. Log In
    3. Add some other item to the cart. (you can remove it later but it has to be something not already in the cart)
    Result:
    Items will show up in the cart again.
  • KeryaKerya Posts: 10,943
    You don't even have to log out and in ... putting something else in your cart usually triggers it into showing all the things inside.
  • caravellecaravelle Posts: 2,755
    Thank you both for your quick response - now it works! :-)
