Odd dress explosion glitch.
Teofa
I have Bobbie25's Alruna armor set. It fits to Genesis fine, renders fine, is fine in a current set.
However, when I load a saved set it literally explodes on the bottom third or so. I have to delete it and load a new one, which will also explode when I reload the saved version.
Running a pretty stock DAZ 4.6 and so far this is the only item that does this.
Post edited by Teofa on
Set Parameter tab to Show Hidden. Select the the offending the clothing and under Mesh Resolution change the SubDivision Algorithm to Catmull-Clark (Legacy). If this doesn't fix it check Mesh Smoothing's Smooth Iterations, a setting higher than 5 can cause weirdness with some clothing.
hmm, subdivision algorithm did nothing, I checked that first since I have some items that need legacy. However, the explosion happens during smoothing, so Ill check that. Thanks.
Edit. Smoothing iterations was the culprit. It was set to 20, each bit I lowered it removed a poly distortion. had to go to 0 to remove all of them,
