Odd dress explosion glitch.
Teofa
I have Bobbie25's Alruna armor set. It fits to Genesis fine, renders fine, is fine in a current set.
However, when I load a saved set it literally explodes on the bottom third or so. I have to delete it and load a new one, which will also explode when I reload the saved version.
Running a pretty stock DAZ 4.6 and so far this is the only item that does this.
530 x 700 - 280K
Post edited by Teofa on
Set Parameter tab to Show Hidden. Select the the offending the clothing and under Mesh Resolution change the SubDivision Algorithm to Catmull-Clark (Legacy). If this doesn't fix it check Mesh Smoothing's Smooth Iterations, a setting higher than 5 can cause weirdness with some clothing.
hmm, subdivision algorithm did nothing, I checked that first since I have some items that need legacy. However, the explosion happens during smoothing, so Ill check that. Thanks.
Edit. Smoothing iterations was the culprit. It was set to 20, each bit I lowered it removed a poly distortion. had to go to 0 to remove all of them,
