In Need of Help
I'm trying to finish a render and I keep getting these black lines under Genesis Breast and Have No Idea what is causing them. If someone could help I would greatly appreciated it.
Can't you soften the shade rate or shadows in DS. Or change the shadows to a different setting.? Also if your displacement map is set real high it will invent a wrinkle where it's not meant to be. You could try lowering it or in this shot turn it off and just keep the bump on.
That looks like Ambient Occlusion to me. Have you tried turning AO off? Are you using the Uber Environment 2 Light?
What are you using for lights? What are their settings?
What are you using for a surface shader? What is its settings
I am using Lantios Lights and ago of armours SSS shader, it also shows up with out lights.
I think its the bump map but its never done that before.
