In Need of Help
JohnDelaquioxJohnDelaquiox Posts: 1,197
I'm trying to finish a render and I keep getting these black lines under Genesis Breast and Have No Idea what is causing them. If someone could help I would greatly appreciated it.
989 x 345 - 53K
  • AntManAntMan Posts: 2,182
    Can't you soften the shade rate or shadows in DS. Or change the shadows to a different setting.? Also if your displacement map is set real high it will invent a wrinkle where it's not meant to be. You could try lowering it or in this shot turn it off and just keep the bump on.
  • DZ_jaredDZ_jared Posts: 1,316
    That looks like Ambient Occlusion to me. Have you tried turning AO off? Are you using the Uber Environment 2 Light?
  • MattymanxMattymanx Posts: 7,002
    What are you using for lights? What are their settings?
    What are you using for a surface shader? What is its settings
  • JohnDelaquioxJohnDelaquiox Posts: 1,197
    edited September 2013
    I am using Lantios Lights and ago of armours SSS shader, it also shows up with out lights.
    I think its the bump map but its never done that before.
    Post edited by JohnDelaquiox on
