DAZ Studio has encountered a fatal error and must close - what does this mean?
Hi there. I just installed DAZ studio for the first time. I intalled DAZ Studio first because I wanted to indicate I wanted it to use a seaparate drive for content. I then realized that I have to use the DIM to install the content (which is just what comes with the program.) Anyway, after about 40 minutes, it finally installed everything, I fire up the program, not 2 seconds after opening it, the program closes and gives the message "DAZ Studio has encountered a fatal error and must close". Is this normal? Do I have to go through the whole reinstallation process again to get this to work? If anyone has any info, please let me know.
P.S. The DIM completely ignored that I requested the material to be installed on the second drive when I installed DAZ studio. If I change the location of these files and indicate it in the program is this going to work?
Does the error give any additional information? The most immediate suspect would be your video card/driver, or possibly your security software - what do you have?
Thanks for responding. I'm using Norton for antivirus and this is on a laptop that uses a Integrated Intel FHD Graphics 520. What's happening is, the software opens, then when I go to select one of the figures, it starts to close down. I even tried just using a primitive and it was ok for about a minute and I figured, ok, so it works with primitives, but shortly thereafter, it did the same thing The Norton does not affect any other graphic software that I have on the machine. The Hexagon software, which was installed much to my surprise, is fine. It only asked for the serial at first, I gave it that, and it opened up fine and had no issues. Also, Norton did not flag the DIM anytime it was downloading and installing stuff. So, I don't know what's causing this.
my advice is
turn off Norton right now, that clogs your system.
change to a dedicated graphics option.
