Super Bodysuit for Genesis 3 Male(s) missing geometry File
When ever I select any of the Geo trims that have the Mask I get the following error. and no mask trim loads
anyone else receive this error?
  • NorthOf45NorthOf45 Posts: 5,841
    Make sure you select the Super Bodysuit before trying to add the GeoTrims.
    Yes. as you can see in the screen capture what was selcted
    Ah. It might work better it if it being worn. Put it on a Genesis 3 Male, it will work properly. This suit works a little differently than I am used to, these geotrims aren't so straightforward.
  • evilded777evilded777 Posts: 2,522
    I didn't use to have this problem, but suddenly I do.  It always wants to install something for a product that is already installed.
    And on a related topic, anyone ever try to use the UV's to design something in say Substance Painter? The UV's are HORRIBLE.
