please can someone help with md and daz studio
lasagnaman
in The Commons
i exported my clothing i made from md now i want to fit it to my genesis 3 female and wont fit its all messed
up please can someone help me i am very upset i worked so hard on this jacket and now i cant use it
what do you mean won't fit? can you post a pic?
Did you make the jacket on a Genesis 3 female in Marvelous Designer?
it doesnt import in t pose
yes i did
Have you seen any of Sickleyield's tutorials such as this one?
thats what i get it fits like that can when i move here the jacket is not on her
(Image removed for nudity. Please review guidelines here https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest ~mod)
yes i have
thats what she looked like in marvelous designer
when you imported the jacket did you choose correct scale? seems to me that maybe that's the issue if the jacket is not on the model
Also, if you're working with Genesis 8, the figure should be in A Pose, not T Pose.
What were your steps after you imported the jacket? Did you use the transfer utility?
yes i used the transfer utility no i am using genesis 3 female
and alll the folds and the stitches arent showing up from the jacket i dont understand
Again, you may want to show images, but no textures on the figure as nude images will be removed.
When you export the base figure as an .obj file from Studio, be sure to also save the .duf scene with the exact same figure pose. That way, when you export the finished garment from MD back into that same scene, it pops into Studio directly on top of the figure. From there, you simply parent the garment to the figure so you can move it around your scene. I don't try to autofit my garments, because I found it's easier to do the posing/draping in MD and export. Previous discussion here: https://www.daz3d.com/forums/discussion/305076/marvelous-designer-and-posed-figures#latest
Hope this helps.
