Fit 'Stalker Girl Hair' on G3F?
Hi!
Do somebody knows if the 'Stalker Girl Hair' made for Genesis (SKU:15884) can be fitted to G3F?
    If you try and 'fit' it to any generation other than Genesis, you will lose some functionality. A better way to use it (or most hair) is to 'parent' it to the head, then adjust the scaling, position, etc. To 'parent' something, just open the scene pane, and drag the item (eg: 'Stalker Girl Hair') with your mouse onto the character's head (or whatever, even a ball, monster, etc). Adjust and you're done.
  • That's good advice in general. For this item in particular: Fit the base, cap, and fringe to G3F using autofit, then parent the tail to the cap.
  • mlominymlominy Posts: 227
    Thanks Dragonfly and Murgatroyd!
    Now, do you know if there is a way to make the hair 'Iray'?
  • Dim ReaperDim Reaper Posts: 687
    edited February 2019
    Stalker Girl was one of my favourite characters when I first started using Genesis with Poser, so I just had a go at fitting the Stalker Girl hair to Victoria 7 and the auto-fit seems to work pretty well.
    As for converting the hair for iray, I tried Sloshwerks' ColorWerks Hair Shaders for Iray and it works pretty well with the Stalker Girl hair.  I've attached a few quick renders below to give you an idea of how the hair looks on G3.
    700 x 700 - 70K
    700 x 700 - 83K
    700 x 700 - 74K
    Post edited by Dim Reaper on
