Finding content installed only to runtime directory
in The Commons
Hi I installed an asset I downloaded from shareCG. I have done this before, but usually I know where to look for the asset in the Daz content menu because generally its under shaders or under a genesis figure, etc. This particular prop was installed only to the 'runtime' directory in my library directory. Under Runtime it had files in geometries, libraries and textures. So in the Daz interface, where do I look to find the asset ? Thanks!
I have this question too.
Content Library tab under Poser Formats.
If there are files under Runtime/Libraries then it's most probably content in Poser format.
In that case you should find it in "Content library" tab (not Smart Content), in the "Poser Formats" section.
In the Poser library you will find the following main sections:
There can be additional ones like Cameras, Lights, Faces, Hands... depending on the content you have.
For the record, I am doing a workshop on custom categories and how to find your content quickly on March 9th.
thank you very much
